Is there a DIY Guide for OEM Brake Upgrade from 2003 model to 2006+
Old 09-02-2014, 02:44 PM
kev_
kev_'s Avatar
Default Is there a DIY Guide for OEM Brake Upgrade from 2003 model to 2006+
Hi Guys:
I was doing some research about upgrading from non-brembo brakes to brembo a while back and I thought I remembered coming across a DIY for upgrading the 2003-2005 brakes to 2006+ OEM. Now, after trying multiple searches using things like "how to upgrade brakes" and "DIY brake upgrade" but can't find it anymore. I only find posts about going from non-brembo to brembo. If someone could point help me out that would be great. If this will get me flamed for not searching (hard enough) then so be it. I just want to know if the thread exists or if I'm just imagining things.
Old 09-02-2014, 02:45 PM
Bmurray350z
Bmurray350z's Avatar
nothing special is required. just unscrew brake lines, take calipers off (2 bolts on each caliper) and put new calipers on. will need to bleed the brake lines afterwards.
Old 09-04-2014, 12:43 PM
kev_
kev_'s Avatar
Thanks Bmurray350z! I don't know why but I thought I read somewhere on a DIY thread that some modification would be required. Good to know now. Thanks again.
Old 09-04-2014, 05:11 PM
POS VETT
POS VETT's Avatar
Don't forget the rotors; they're a bit larger.
Old 09-04-2014, 05:32 PM
Bmurray350z
Only modification is to cut the rear brake dust shields where they bend over the standard rotors
Dsowe
02-17-2021 10:38 AM
burglapfd
12-06-2020 01:04 PM
samansharif
09-25-2015 12:31 PM
Quick Reply: Is there a DIY Guide for OEM Brake Upgrade from 2003 model to 2006+
