Is there a DIY Guide for OEM Brake Upgrade from 2003 model to 2006+ - MY350Z.COM Forums
Thread Tools Search this Thread
Old 09-02-2014, 02:44 PM   #1
kev_
Default Is there a DIY Guide for OEM Brake Upgrade from 2003 model to 2006+
Hi Guys:
I was doing some research about upgrading from non-brembo brakes to brembo a while back and I thought I remembered coming across a DIY for upgrading the 2003-2005 brakes to 2006+ OEM. Now, after trying multiple searches using things like "how to upgrade brakes" and "DIY brake upgrade" but can't find it anymore. I only find posts about going from non-brembo to brembo. If someone could point help me out that would be great. If this will get me flamed for not searching (hard enough) then so be it. I just want to know if the thread exists or if I'm just imagining things.
kev_ is offline   Reply With Quote
Old 09-02-2014, 02:45 PM   #2
Bmurray350z
nothing special is required. just unscrew brake lines, take calipers off (2 bolts on each caliper) and put new calipers on. will need to bleed the brake lines afterwards.
Bmurray350z is offline   Reply With Quote
Old 09-04-2014, 12:43 PM   #3
kev_
Thanks Bmurray350z! I don't know why but I thought I read somewhere on a DIY thread that some modification would be required. Good to know now. Thanks again.
Old 09-04-2014, 05:11 PM   #4
POS VETT
Don't forget the rotors; they're a bit larger.
POS VETT is offline   Reply With Quote
Old 09-04-2014, 05:32 PM   #5
Bmurray350z
Only modification is to cut the rear brake dust shields where they bend over the standard rotors
Thread Thread Starter Forum Replies Last Post
Headlights Dsowe Exterior & Interior 9 09-28-2015 10:05 AM
Transmission drain plug gasket/washer size? burglapfd Maintenance & Repair 0 09-26-2015 05:46 PM
Annoying sound when braking lightly samansharif Brakes & Suspension 1 09-25-2015 12:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright 2002 - 2008, MY350Z.COM All Rights Reserved.
