eibach ESS springs - questions
on
where can i find more information on these springs? i can't find them on the eibach site, only on some vendor sites via google
are linear, come in various lengths/spring rates, and have an OD of our OEM rear. not sure if available in OEM front OD. they seem perfect for those wanting to choose their ride height and spring rate, or am i dreaming?
Gsedan - from an old thread of yours you list the OD's
front - Outside Diameter 4.5"
rear - Outside Diameter 5.0625"
do you have the OEM lengths measured for baseline?
thanks
pp
thanks
pp
The ESS springs are only a solution for the rear, other then doing a coilover conversion like I did their are no front spring option's other then current crop of lowering springs on the market.
This is what I have at this moment
Oem rear spring free length for 350Z's with the revised suspension (427lbs) 2004.5+
12 7/16"
Free length for rear Tein 350Z H-tech's 12 1/4" (375lbs)
Somewhere in a notebook I've manged to misplace, I have the free length of the rear oem Z springs from 2003-2004 cars (342lbs), I am almost certain it is 12 3/4"
So the question that I never got around to, which ESS free length would be the best choice. That would depend on desired rear drop and the rate choosen. You can effect rear ride height seperate from the spring length by making changes to and or above the rear upper spring seat. You can add up to a 3/8" shim above it to gain that much rear height, or you can cut it down from it's 1 1/4" thickness to as little as 1/2", but make no mistake, cutting it is NOT easy. I don't see any reason why someone couldn't use one of Energy Suspension's 3/8" thick poly bushings as a new upper spring seat.
On the left is a uncut oem rear upper spring seat. On the left is a cut down spring seat with a pair of 3/8" spacers to bring it back to near oem bushing height.
12 7/16"
on
One thing to note is the you may have to trim an inch or so off the the bottom of a linear sping to sit right in the bottom tray. This was done to my hyperco's.
Perhaps you could just trim the spring more or less to get the desired ride height. (I'm having a hard time picturing the indentation of the lower spring basket in my head so I'm not sure if that would work or not).
Another option would be to call up tein and buy their rear perch and any of their linear springs.
Performance Nissan
Performance Nissan
Would the TEIN springs work?
They have different replacement springs with various sizes / lenths...
http://performancenissanparts.com/ca...?cPath=292_857
The thought of the pig tail fitting in the oem lower seat cup did occur to me, hard to tell in pics of the ESS springs,
Performance Nissan
Performance Nissan
Originally Posted by Gsedan35
Tein does not list the 5" outside diameter springs they use in rear with their coilovers as a seperate part, not even on their web site in Japan. But, whenever I've called Tein they talked about how I could order them from any authorized Tein dealer. Basically I tell the tech what I want, he give me a part number that I give to you. Thing is, they might only sell the rear springs to those that can prove they own a set of Tein coilovers since the spring is not part of their regular lineup, just like they refused to sell me coilover parts. At least they are good people to talk to on the phone
I am an authorized TEIN dealer...
Here is a link to the rear replacement springs for 350Z / G35 tein coil overs...
http://performancenissanparts.com/ca...h=292_1319_935
I have them on there...
But, how tall are then in free length? Way to go to have them listed on your site
Performance Nissan
Performance Nissan
They are what ever come with the TEIN Flex / CS as far as free length and OD... Ill see if I can find out from TEIN today... They might be a bit short I think though since they are made to go on the upper spring perch for their coil over set up...
But, these springs are made to order... So I can most likely get some made with a longer free-length to work with the stock upper mounts...
on
"The ESS springs are only a solution for the rear, other then doing a coilover conversion like I did their are no front spring option's other then current crop of lowering springs on the market."
forgive my ignorance. what is it about the 350z's front that a 4.5" OD from tein or ESS won't work?
thanks
thanks
thanks
thanks
Thread from the dead! Haha.
Is the Eibach ESS still the only OTS rear spring that we can use at the rear? I am looking to swap the rear springs to a higher spring rate on a set of coilovers I bought (the spring sits in the OEM rear bucket still).
I see Landrum makes some: http://www.summitracing.com/search/p...cing%20Springs
as well as Eibach (but couldn't find availability of the Eibach ESS): http://www.summitracing.com/search/p...cending&page=2
08-06-2021 06:19 AM
