Lowering Springs Picture Thread
Old 06-16-2009, 06:49 PM
  #41
singh
_______________
singh's Avatar
i'm looking for springs that give a dead even drop. Out of all the pics I have seen, Cobb does the job best.
Old 06-16-2009, 08:50 PM
  #42
350ZthatsMe
350ZthatsMe's Avatar
I'm trying to decide between the Cobb and the RSRs.. the Cobb gives a better drop but I think the spring rates are too high for stock shocks.. I've also heard some have had problems with the spring sitting on the perch correctly..
Old 06-17-2009, 03:44 AM
  #43
singh
_______________
singh's Avatar
yeah that's what I heard also, lately I have been looking at the Tokico Dspec shock & spring combo. The pics I have seen for them also gives a nice even drop and people say the ride is nice and you can adjust the stiffness easily.
Old 06-17-2009, 04:18 PM
  #44
Dr. Venture
Dr. Venture's Avatar
Billstein Pss9/10's.
I didnt go crazy low only cause i would not have been able to get into driveway, and alignment lift for when i need work done. Front lip just by a hair clears the lift now.
Old 06-17-2009, 06:45 PM
  #45
jammin
jammin's Avatar
^^Aren't the Bilstein Pss10s coilovers? If those are the coilovers, I didn't even know they went that low.
Old 06-17-2009, 07:03 PM
  #46
Dr. Venture
The Box says pss9/10 so i think i have 10 front and 9 rear or maybe just 9 all around. Im not positive, but it does go pretty low so far. And i do have room to go lower still, but if i do i wont be able to do certain things, like go home.
I always thought the pss9's only had 9 click adjusting #'s for the damper settings, but mine have 10...so beats me.
The part # is F4-GM5-E614-H0. Every time i look it up comes up as pss10.
Old 06-17-2009, 07:11 PM
  #47
marques1
marques1's Avatar
lvz053: We'll with 19inch wheels im not to sure how much you will have to cut to get an even drop. I had more to cut of the mount if i wanted to so the rear could possibly go lower. As far as the ride you won't notice any difference it feels pretty much stock. My wheel setup is more aggressive than yours and i dont rub so...no you won't have a rubbing issue. like you said it is mandatory to have a rear camber kit though.
Old 06-17-2009, 07:31 PM
  #48
Ztouring04
Ztouring04's Avatar
i have Tein S-techs with rear spring mount cut............
Old 06-18-2009, 06:45 AM
  #49
pony_killer
Arada ninda apa
pony_killer's Avatar
Tanabe NF claims 1.25 all the way around, I have them on my Z and after they settled the front looks very nice but the rear needs to be lowered a bit more..am thinking of doing the rear mod that a lot of folks on here are talking about.
Old 06-18-2009, 03:49 PM
  #50
marques1
marques1's Avatar
pony-killer>>>>>do it you will be pleased with the outcome!!
Old 06-18-2009, 06:51 PM
  #51
MyZ4U2C
MyZ4U2C's Avatar
Very sweet! Who makes those springs and what wheels are those?
Originally Posted by marques1
gf210 springs with bump stop mod in rear:
Old 06-19-2009, 12:36 PM
  #52
GeauxLadyZ
GeauxLadyZ's Avatar
Tanabe springs / Axis Shine 20" wheels.
Old 06-19-2009, 12:48 PM
  #53
PhatZooM
PhatZooM's Avatar
tein s-tech stock shocksName:  week1.jpg
Old 07-25-2009, 05:08 PM
  #54
brandon3434
brandon3434's Avatar
eibach sportlines, 25mm rear spacers, 20mm front spacers
Old 08-18-2009, 06:57 PM
  #55
Imnu2dis
Imnu2dis's Avatar
Nice!
Old 08-18-2009, 07:05 PM
  #56
jduet
jduet's Avatar
Lowered on Tanabe GF-210's with SPC rear camber kit
Wheel specs are 18"x10" +18 all around with 15mm spacers out back.
Old 08-19-2009, 06:00 AM
  #57
GeauxLadyZ
GeauxLadyZ's Avatar
S-Techs.
Old 08-19-2009, 03:17 PM
  #58
nismonian
nismonian's Avatar
more pics of prokits?
Old 08-19-2009, 04:16 PM
  #59
08nogaroZ
08nogaroZ's Avatar
anyone have GF210's without the rear mod and without camber kits? any alignment problems? such as too much negative camber? considering these springs and I would really appreciate the info.
thanks
Old 08-30-2009, 07:51 PM
  #60
starvinmrvn
starvinmrvn's Avatar
GF210's with stock shocks...First picture is before 25mm spacers and spc rear camber arm and toe bolt. I did not check the alignment before installing camber kit. Take it for what its worth but definatly looked like way more negative camber before the kit.
Quick Reply: Lowering Springs Picture Thread
