Lowering Springs Picture Thread
Old 12-12-2009, 11:25 PM
  #141
SQBassHead
SQBassHead's Avatar
Question
sorry for the random question but for eibach sportlines i know rear camber kit is needed and front is recomended, but how many of you pulled it off with out the front kit? and how many miles so far? thanks
Old 12-12-2009, 11:35 PM
  #142
calin
calin's Avatar
I had Sportline springs for about 25k miles with only a rear camber kit. The fronts had VERY little camber wear even without a camber kit, so I got lucky. But others with the same springs have a lot of camber, so you either get lucky or you don't.
Old 12-13-2009, 05:39 AM
  #143
ReV2Red
I haz da turbos
ReV2Red's Avatar
My old setup. Tein S-tech with 8mm springmount chop. Bare in mind that here the car had the boot gutted, and the gas tank was on empty.
Old 12-13-2009, 08:15 PM
  #144
Blackheart
Blackheart's Avatar
Finally, Im pulling the trigger and lowering the Z.
I have read so much about different springs, shocks, coilovers and anything suspension related but still have some doubts. Figured I would ask you seasoned guys since I found this great thread.
I was thinking about full coilovers but I have been advised it would be overkill since I dont track my z or even ride it harshly.
I wanted a mild 1'' drop so im going for the eibach pro springs on 245/35 +23 offsets and 275/35+24 work meister wheels.
-Questions
Do I need the tokico D shocks since they are "recommended"?
Do a Need a rear camber kits?
Will this setup require fender rolling?
Thanks for any info guys! I appreciate this thread lots of info and great pictures
Old 12-13-2009, 09:07 PM
  #145
Anomaly
Anomaly's Avatar
Originally Posted by Blackheart
-Questions
1. No, but from my experience upgrading from the OEM shocks is a good investment and can/will save you some issues later.
2. Rear camber kit is a 'maybe' answer but I went ahead and purchased the kit with my springs and had everthing installed at the same time. If I hadn't I'm pretty certain that the rear kit would have been required to be added anyways so playing it safe paid off.
3. No, you will not require fender rolling with that set up. I have 245/35/19 with +18 up front and 275/35/19 with +22 in the rear with room to spare on the Pro-Kits.
Old 12-13-2009, 09:20 PM
  #146
Blackheart
Blackheart's Avatar
Thank you SIR! Thank you for all the info! your answer has definately answered my questions and wiped out any doubts. guess the old saying is true
" if you are going to do something, Do it right the First time!"
Old 12-14-2009, 06:43 PM
  #147
Blackheart
Blackheart's Avatar
just found out about cobb springs by accident. I read on two vendor sites that cobb springs lower the Z 3/4 in the front and in the rear since they are designed to be direct replacement for the stock ones and work with the stock shocks as well.
Does anybody have them installed? Any opinions, pictures, or thoughts about this brand?
Old 12-14-2009, 07:07 PM
  #148
stogey420time
Club Moderator
the Hot Spot
stogey420time's Avatar
My friend Pedro is running Cobb Tunning springs. He's loving it so far
I like the aggressive stance so I would opt to go lower and he doesn't want to go too low b/c it'll hinder the performance aspect.
Old 12-14-2009, 07:10 PM
  #149
jasabeast
jasabeast's Avatar
Go with Eibach... prob the best made springs out there they come with lifetime warranty and chit.. i had Tanabe good spring and decent lowering.. i took them off and went true coilovers... and i had to roll my fenders with the tanabe springs.. 18x9 +20, 245/40 in front and 18x10 +18, 275/40 in rear, im on Work XD9's..
Old 12-14-2009, 07:46 PM
  #150
Blackheart
Blackheart's Avatar
Looks good since these cobb springs are close to stock specs according to the vendors. I doubt it but Did your friend need a rear camber kit?
The drop looks pretty good If I dont need a rear kit or new shocks I may just get these and some other goodies.
Old 12-14-2009, 07:48 PM
  #151
jasabeast
jasabeast's Avatar
looks dead stock with the cobb springs...
Old 12-14-2009, 08:13 PM
  #152
stogey420time
Club Moderator
the Hot Spot
Well, he bought the rear kit anyways and I'm sure you won't need it since it's a minimal drop. My other friend have Tein S-tech which are close/same drop and didn't need rear camber kit.
Every car is different, so
Buy/install springs first.... get alignment and decide then.
Old 12-16-2009, 11:59 AM
  #153
Blackheart
Blackheart's Avatar
I will probably go with eibach pro. Seems to be very consistent with the drop and no unnatural excessive sagging. Just to let you guys know there are 2 group buys right now one with B2autodesigns and Kevin@usautotech.
Thanks for all the info guys
Old 12-16-2009, 01:14 PM
  #154
ITOzann
ITOzann's Avatar
I'd recommend B2sutodesigns!
Old 12-16-2009, 09:55 PM
  #155
Blackheart
Blackheart's Avatar
im in with B2autodesigns just waiting for 4 more spots to fill in
Old 12-24-2009, 04:22 PM
  #156
sosojeffcc
sosojeffcc's Avatar
Hotchkis springs. 20mm/25mm spacers f/r.
Old 12-30-2009, 09:40 PM
  #157
sfearl1
sfearl1's Avatar
does the hotchkis require a camber kit?
Old 12-31-2009, 05:32 AM
  #158
Dr. Venture
Dr. Venture's Avatar
Originally Posted by t-350z
does the eibach sportlines require a camber kit?
From what i have seen here at the shop any Z or G thats being lowered by any kit so far has needed a rear camber kit......stock and or aftermarket wheels.
Old 12-31-2009, 05:41 AM
  #159
Dr. Venture
I see the Cobb Springs work just as well as there little Tuning computer....keeps the car feeling and looking BONE STOCK!!
Old 01-06-2010, 07:35 AM
  #160
arsey51
arsey51's Avatar
I installed the Hotchkis lowering springs a few months ago. I only wanted a mild drop from stock and thats pretty much what I have, however, the passenger side rear tire and wheel gap is more than the driver side gap. I can tuck my pinky finger between tire and wheel well on the drivers side and I have a two finger on the passenger side. Could it be faulty springs? Anybody else run into uneven lowering? Can springs be returned/exchanged? I'll also contact retailer I bought them from. Any suggestions/tips would be apprecieated. I just replaced rear tires, went from 275/40/18 to 285/35/18 and the rear gap on the passenger side really bugs me.
Quick Reply: Lowering Springs Picture Thread
