**Steering knuckle ball joints??**
#184
on
#185
So my ex-wife works for a dealership so she can get parts at cost from the local Nissan dealership.
What part numbers do I need to replace the OE ball joints and steering knuckle.
#186
Under Boost!
my driver side knuckle joint is somehow damaged (dunno how). i called up the dealership and asked for the assembly.. it was priced @ $2500 ...................
on ebay, a used (in a good condition) one was for $150..
i still didn't fix mine, the clicking noise is bothering me, but i cba to fix it.
#187
Theres no way it could be $2500. Is this with labor? Even still thats ridiculous. Id recommend going with a new one, since you never know what a used one has been through. I was quoted 400 plus a couple hundred in labor to replace mine with a new OEM piece, from a reputable shop.
#189
Under Boost!
we end up buying from abroad to save up! most things aren't reasonable in this country.
#191
someone on driver is using the ebay balljoints and these
http://www.energysuspensionparts.com...p?prod=9.13130
on driver : http://g35driver.com/forums/brakes-s...ight=balljoint
#192
Retired Admin
I haven't looked under the car to specifically check the ball joints, but I haven't had an issue with the eBay one that I purchased years ago. I've been to several track days and even more autox's, drove across country a few times, and daily drove on them.
#193
on
I did these a month or two ago: http://www.meganracing.com/product_d...d=850&catid=26
No problems so far.
No problems so far.
#196
http://g35driver.com/forums/6530887-post31.html
I would think an aligment would be needed. Let me know how this work out. I need to replace my pass side soon.
#197
on
Just to be clear the lower ball joint, refer to the bushings for the steering knuckle, right? Because the dealership told me there is no replacement bushings available, which is why the price so exorbitant on the knuckles. That duralast model looks to be pretty solid, but I take that megan racing roll center adjuster is also the bushings for the steering knuckle? Thanks.
#198
With the dealership there is no replacement for the balljoint. They can only see you the entire assembly. If you're trying to replace just te bushing you should make sure the greese isn't bad or there's no dirt in there
#200
they are not bushings, they are ball joints
if I want to just change the boot with energy 13009 and fill it up with grease would there be anything wrong with going this route as opposed to changing the ball joint with the duralast
thanks
thanks
