**Steering knuckle ball joints??**
#302
I am waiting to hear back from Nissan on a price for a knuckle. The site I use lists two different knuckles that vary by about $70.
What is with all of these variations? Most of this thread assured us that there are none.
Sure hope I get the right knuckle! Anybody have experience with buying a knuckle?????
#304
ok so my ball joints are shut. I bought a pair on amazon MTC branded for 43.99 on prime. Ball joints came in and they're exactly the same people have been showing here from eBay etc.My problem is that when i compared them with the OEMs on my 2006 Z, they're smaller. Shall i try to force them in to see fitment or what? I was also thinking in buying the energy suspension boot to see how that worked out, but wont do it until I find out what to do with these suckers.
Somebody please chime in!!!
#305
#306
Master
i just went through this... bought some off amazon and they were shorter and thinner in diameter ... just like the autozone ones.... good luck finding something i ended up replacing both my steering knuckles and an alignment for $1100. i think in 06-08 they beefed up the front suspension compared to the earlier models and every just assumes the older de ones will work
#307
It sounds like from your description you are experiencing the same thing I did with a part from Autozone. The bottom case looked like it would fit in the knuckle but the stud was too small. Both the threads were smaller diameter and the stud was shorter - smaller in every way. I checked with Nissan on all the model years to see if a different size seat (the cone shaped piece that will not be able to be transferred from your old part to the wrong part because it will be too big on the inner diameter) was available to make the part work. There is only one size seat available and the part will not work. Plus why would you want to make a part work that is smaller than the original? Probably not 100% safe. It is not the right part. You are probably stuck buying a new steering knuckle from the dealer like I did.
#308
Guys, I can say proudly that they worked well. I was able to install them in my 06 without any problems, I would've tried to install the urethane boot but didnt do it for now, but they work well, the only thing you've got to make sure is that the ones that you buy come with the metal cone seat. Will put pictures later with them installed.
#309
on
Can you send me the link to your joints? On the same fkn boat!
#310
Master
#311
Here's the link for the ones i used:
Keep in mind as a disclaimer, there's people on the reviews that say that they didn't came with the seats, neither they appear on the pictures, only thing i know is that mine did, they DO have a difference from my 2006 OEM's, they were shorter and a thinner, but only by a little, i took my chances and until now they working like they're supposed to. I wish everyone good luck if you guys try, but dont come flaming if something goes wrong or doesn't fit properly. Remember to apply more grease on them, because mine came with little.
Amazon.com: Nissan 350Z Infinifi G35 Ball Joint Kit - Front Lower Control Arms | Two (2) Pieces | Fits Left and Right: Automotive
#312
Master
#313
Hey there.
A mechanic installed the ebay ball joint together with complete energy front bushing few weeks ago. Right after the installation, i heard a clunking\knocking sound whenever i turn the sterring wheel. We double chcked everything and he identify that the noise comes from one of the ball joint. Do u think i got a faulty ball joint or issit because of installation error by him? And guess what, starting from Yesterday i can hear the same noise from the other side too.. Any suggestion on what to double check?
Thanks in advance
Thanks in advance
#314
So over the past few weeks I've noticed a squeaking noise from my right front wheel when I turn the steering wheel at low speeds. It sounds like a creaking, rusty door hinge. I am thinking it is coming from the ball joint because that's where the noise comes from when I drove the car on ramps to diagnose. Just wondering if you guys have any thoughts about what it is? By the way, I have eBay ball joints on my car for about 2 years now.
#315
Hey there.
Thanks in advance
Thanks in advance
#316
on
I changed both my front lower ball joints today with Duralast ball joints (pn# BJL148). Install took a few hours from start to finish for both sides. Driving the car afterwards the car felt very solid and smooth. So far I'm happy with the Duralast Ball joints.
#320
