**Steering knuckle ball joints??**
#341
How the **** did some of y'all do this in 45mins? I've spent the last 5hrs getting the drivers side done and no this isn't my first time doing ball joints or turning a wrench. I've had to custom make adapters cause the O'Reilly's kit is about 1/2" to short. And beyond all that, the damn thing went in slightly crooked so now I've gotta start all over. FML
#343
Well the second one came out and went back in like a ball joint should. I bought mine from I believe z1 and the new ones went in nice and snug. Can't wait to drive it tomorrow.
#344
So has anyone ordered and installed the Mac Auto Parts ball joints? Any fitment issues or anything I need to know about? Thinking about picking up a pair. Thanks guys!
#346
so is it a a definite model year difference now? it's weird that nissan uses the same part number for all the knuckles. but i guess the bj could be different as long as the cone OD is the same and mates with the control arm the same way.
#351
FYI
I had a torn ball joint boot and was following this thread from the beginning to pick the best option.
My opinion is that the best replacement are the Moonface ball joints but they are outrageously expensive.
Also for anyone reading this, apparently the size of the ball joint its different depending on the year of your Z. If you look in Courtesy parts you will see that there are a couple of different steering knuckles (where the lower ball joint goes) and depending on the year and side, price varies.
Also if you look in Concept Z Performance they offer different ball joints depending on the year of the Z, so be careful when you order.
Now the reason I'm posting its to share this ball joint I found in Z1 Motorsports by Mevotech.
http://www.z1motorsports.com/350_g35...oducts_id=8187
I changed them and they work on my 2004 Track edition.
Model Number according the invoice is MMS30500.
Here's a picture from when I received them:
Be careful that there is another part number by the same manufacturer that looks different than these.
If you can notice the design of the dust boot is quite different than the other options I've seen. That is the reason I chose this ones. They feel very sturdy, but only time will tell.
Another plus is that they are serviceable.
Finally if you buy this ball joints be aware that you will need to reuse the metal cone shaped thing of the old ball joints.
The guy I took it to remove the old ball joints from the knuckle and press the new ones told me that sometimes those can be a PITA to remove without damaging them, so you might want to buy new ones.
Hope this helps to anyone.
And sorry for any grammatical errors, english is my second language.
#354
FYI
I got the CZP cones for the 05 Z....I hope to God they fit.
#355
You can check with your VIN in Nissan Parts Deal
http://www.nissanpartsdeal.com/
and verify the part number.
#356
And you might want to order some cotter pins and nuts in case something strips.
I got lucky with the cones, but not so with a couple of nuts and bolts.
Use plenty of penetrating lubricant.
And hopefully the other ball joints wont need replacement.
Mine do...
Mine do...
#357
Just to update this thread and share my knowledge on the subject. Nissan beefed up the ball joint on the 05+ models (larger and longer stud). Nissan also made slight changes to the ball joint seat in order to accommodate the bigger ball joint stud. As a result, slight changes were also made to the lower control arm to accommodate the new ball joint and seat. To my knowledge, the steering knuckles are exactly the same between the 03/04 and 05+ models except for the ball joint that is pressed into them (same base diameters). This is what I have gathered just from extensively analyzing the online parts catalogs and stores. Unfortunately right now, any aftermarket joint that you buy will more than likely be for the 03/04 z. Not sure why almost every aftermarket manufacturer is stating "fits 03-08 z's". Conceptz knows there are differences and sells an 05+ ball joint that is really an 03/04 joint, however the seat provided with the joint has the inner dimensions of an 03/04 and the outer dimensions of 05+ seat. So the price difference between the czp 03/04 and an 05+ ball join is justified in that you are paying for a custom made ball joint seat that adapts the 03/04 joint to the 05+ control arm. My issue is I like to think that Nissan made a larger ball joint stud for safety, peformance, or durability reasons and possibly all of the above. Unfortunately, the pickings are slim if you want the oem spec 05+ ball joint. I recently picked up the deeza ball joints listed in their online catalog (Part# IN-G605) specified to fit only the 05+ z's and there is definitely a big difference when I compared it to an autozone/duralast joint. Right now, Deeza is the only manufacturer that I know of that sells a ball joint with the oem 05+ stud and believe me I have searched extensively. The only other option is to buy the entire oem 05+ steering knuckles with the joints already pressed in. I have yet to install the deeza joints but will be doing so within a week; they look like they are of decent quality for sure.
On a side note, Mevotech also understands that there are differences between the 03/04 and 05+ joints hence why their catalog list their joints as only 03/04 compatible however some vendors are still slow to change their product descriptions. I have contacted Mevotech and they have told me that they plan to offer an oem specific ball joint for the 05+ very soon which would be nice being that they seem to be the only ones making their aftermarket ball joints serviceable.
I have learned most of this the hard way being that my ball joint boots tore a few months back and began leaking grease all over my wheels. So I had the autozone/duralast joints installed in my car as I thought they would work. Unfortunately, the shop that installed them failed to realize any differences between the parts which is why I will be changing them myself this time. At this time, my front front end just feels wrong and goes out of alignment within a few days after having it professionally done. So I thought I would post this just so those of you who have an 05+ don't make the same mistakes I did.
And if you are interested in the deeza joints it would probably be best to contact their office directly via phone and order them as I only know of one vendor that currently sells them online. It is my understanding that rockauto used to but it seems they don't anymore.
