You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
i just got a good deal on a set of stop tech front brakes. it came with the 4 piston caliper 2 peice rotors pads and braded brake lines plus mounting brakets my question is will they wrk on my 08 z with reg brakes .also will oem brembos off an older z wrk on it because i might try to trade thes for a set of oem brembos let me no what u guys think...
before going on, i'd probably do a couple of things first to verify that StopTech kit will work.. not all stoptech calipers are the same for all the Zs...
depending on what year that Stoptech kit was made, the piston sizing is different to accomodate the brake bias from factory due to changes in weight of the car, power, etc.
you should probably figure out the piston sizing of the stoptech kit (measure it) and give stoptech a call and figure out if its ok for your 08.
another thing to make sure is the knuckle sizing for the bracket on the OEM brembos, you might need new bolts to attach it to the knuckle, the OEM bolts from the non-brembo equiped cars might not work.. you might want to search that because i think it was different when i sold off my OEM brembos to a non-brembo car back in the day-
__________________ Cheston s Sponsors: TechnoSquare|Cosworth|StopTech|Toyo Tires|OS Giken USA|KW Suspension|Koyo Radiators|Motul|GT Spec|K&N|HAWK Performance|Performance Nissan|Rays Engineering|Finishline Autocraft. Thanks: Z1auto|VIP Status. Join the Salad Bar Club. Castrol Syntec Top Car Challenge '09: 2nd Place (Team Super Street). Sport Compact Car Magazine Ultimate Street Car Challenge 2008: 2nd Place.
Nope. You never have to change M/C's with our kits.
And why would you go with OEM Brembo when the ST kit has more heat capacity, larger rotors, stiffer calipers, lighter rotors.
Yeah, I was gonna say... Brembo's aren't anything to write home about. I'd pick StopTech (or any other aftermarket setup for that matter) before Brembo every day of the week.
__________________
I need a job like WOW. This laid off on unemployment thing? ...it ain't workin.
for the oem brembo's... you need the bolts that attach the rear caliper to the knuckle. the front mount straight on. of course you have to use the rotors that goes with the brembo calipers.
basically, you need new bolts in the rear for the calipers that match the brembo's.
