Suspension 101
Old 07-21-2014, 07:34 PM
  #861
VeeCueZ33
VeeCueZ33's Avatar
delete post
Old 07-28-2014, 02:40 PM
  #862
lowtempo
lowtempo's Avatar
Default Tein S-Tech to Tein Basis coilovers
Hi everyone. I had Tein S-techs on stock shocks and just had sent in my car to the local shop to install new Tein Basis, on my 2004 350z.
I asked the shop to lower the car (1/2 inch lower) than what it was on with the Tein Stechs. They just called and let me know that they have lowered the rears the lowest it can go and it is still 1/2 inch higher than what it was with the Tein Stechs.
Can this be correct? Is the Tein basis coilovers 1/2 higher than Tien S-tech springs, even on its lowest settings?
Old 07-31-2014, 07:35 AM
  #863
F2CMaDMaXX
F2CMaDMaXX's Avatar
I just read through the first few pages again, and although it looks like a possible compression bushing issue, the description from a site selling them didn't match up.
BIG Problem driving home last night;
Starting from a standstill, moving off slowly, the steering wheel will move a few inches to the left as if it gets to one point on the tyre, then stays there, another rotation and it moves a couple more inches.
If i reverse, it moves to the right instead. This is creating a 'shimmy' at about 5-10mph and a vibration as i go faster.
Does this sound like compression rod bushings or something else?
I checked the tyres/wheels and they seem ok. Car is standard height/running gear and ~88k miles.
Old 07-31-2014, 12:33 PM
  #864
350slug
350slug's Avatar
I had a similar issue in my g35. It was a busted band in my tire. Made like a ping pong size bump. Took me forever to figure it out lol
Old 07-31-2014, 12:57 PM
  #865
F2CMaDMaXX
F2CMaDMaXX's Avatar
I really was wondering if it was a bulge in the main part of the tyre, i checked it as best i could (not very well) when i got in, but i need to actually go out and do a real check tonight.
I'll also add that the tyres are old, on their way out, and whilst there is tread left, it's close to sketchy. Also, the long drive was all at speed.
The other thing i suspected just now is a possible wheel bearing issue?
Old 08-02-2014, 09:25 AM
  #866
kylin nelson
kylin nelson's Avatar
Hey im I got new front uppper control arms and rear tracction and toe arms but im trying to find a new rear lower control arm and then the front compression arms and the transverse arms any ideas
Old 08-02-2014, 09:40 AM
  #867
F2CMaDMaXX
F2CMaDMaXX's Avatar
Wanted to update in here, seems the problem i was experiencing wasn't suspension/bushing related.
The tyre has a two inch wide bulge in it that reaches about a third of the way round the circumference.
Old 08-21-2014, 04:13 AM
  #868
Kileak
Kileak's Avatar
I had missed the part about the Energy Suspension compression rod bushings and had swapped everything in the front to them (purchased complete front kit), only to realize this is how they sit if your suspension is dropped:
So, as JasonZ-YA and others have said, stay away from them if you're lowering the car, you're better off with OEM replacements and changing when they tear, or going with the SPL, which is what I did and they are great!
Old 09-14-2014, 05:08 AM
  #869
Birger Øen
Birger Øen's Avatar
I'm upgrading the suspension on the car in the winter, to wondering if you can find a good setup to me. car is for daily use and sometimes the track of the year.
has today Bilstein PSS10 coilover 1.18-1.37inch lower, Nismo body damper and diff bushing.
What I think is: h&r sway bar, SPL Pro Solid subframe Bushings, hardrace rubber bushing arm, hardrace rubber bushing and maybe roll center adjuster and moonface upper arm.
will not have too much noise and vibration.
everything should look as originally as possible.
What do you think of this setup?
do you recommend some mono ball bushing, is not it too much noise and vibration to normal use?
The car has been on corner weighting. Front 898lbs and 890lbs, rear 782kg
Front caster 8`30 and 8`49
Front camber 1`47 and 1`52
Front toe 0`01
Rear camber 1`49 and 2`19
Rear toe 0`04 and 0`07
Old 11-21-2014, 06:55 AM
  #870
djmike350z
djmike350z's Avatar
Default Personal opinion and suggestion on these coil overs?
Can anyone give me an input in which brand of coils would be best used for daily driven and occasional track use (2-3) times a year,
Hsd
BC
fortune auto
Old 11-21-2014, 07:59 AM
  #871
voltexz
voltexz's Avatar
I personally wouldn't use any of those but then again what is your price range?
Old 11-22-2014, 06:42 PM
  #872
terrasmak's Avatar
Received 2,284 Likes on 1,646 Posts
KW V2 , not much more but a hell of a lot better.
Old 11-27-2014, 02:18 PM
  #873
gee805
gee805's Avatar
Default KW V2 coilovers (and other brands) with KYB strut mounts
I can't seem to location any of this info from searching. I've done alot of snooping around for may years and haven't logged in. haha (Not sure if any of you old school guys remember the Oxnard Nissan Bash car show days. That's how long- I was one of the locals helping out with it)
Anyhow I'm pretty sure I know my answer but would like to post this out for others to see that might have the same question (I did not notice it go into details in the suspesion 101- make we can add details on the brands/types along with i read that 2nd generations mounts would work too?)
I finally bought some legit coilovers. I purchased a pair of KW V2 from ZSpeed. While these are been shipped as we speak, I would like to know if I can run the KYB front and rear mounts with the kw v2 (or in fact should I ask, is there any type that it won't work on). I image so but just would like to double check.
Also I would like to thanks all the old school guys that have put work in. Thanks guys for been pioneers. (even the guys that may not be around anymore)
Old 12-02-2014, 11:25 AM
  #874
dragon11689
dragon11689's Avatar
@jasonz-ya the part where you mentioned to cut a 1 1/8 hole with a bi metal drill bit on the rear strut bar frame to gain access to rear coilover dampeners...I did just that but hole is only big enough for 1 finger to reach down and barely touch the side of dampener dial. Can the hole be cut wider?
Old 12-02-2014, 11:41 AM
  #875
travlee
Master
travlee's Avatar
Received 9,047 Likes on 6,513 Posts
do the top of your coils (or shocks) have an allen key hole in the top of them, if so go to harbor freight or someplace and get a long allen key to fit it and put through that hole to adjust. he is an engineer so i am pretty sure he said that size for a reason
Old 12-02-2014, 02:43 PM
  #876
dragon11689
No unfortunately, I have this type of dial:
I've tried pliers but they are a b*tch to turn with pliers. It keeps slipping when I try to rotate the dial.
The left one seems to rotate somewhat, but the right one doesn't seem to budge. I'm not looking forward to removing the coilover again. It is a huge P.I.T.A.
Old 12-02-2014, 03:35 PM
  #877
travlee
Master
travlee's Avatar
and greedy doesn't make extensions?
Old 12-02-2014, 04:04 PM
  #878
dragon11689
Not that I know of. I checked online and didn't see any. I can try to call them to see tomorrow just in case they do, but it's not available online.
Old 12-02-2014, 04:08 PM
  #879
travlee
Master
travlee's Avatar
well i found this on a diff site, and it says it has extensions.... maybe they do make them
http://forums.nasioc.com/forums/show....php?t=2592147
Old 12-02-2014, 05:07 PM
  #880
dragon11689
Nice find! I'll call Greddy tomorrow. Thanks.
Quick Reply: Suspension 101
