Motive Power Bleeder opinions?
#64
I was just going to go with the beer bottle method lol
#66
on
I have the 1107 Ford 3-prong adapter but it's not holding pressure. I pumped to 10psi and air would leak out completely in about 3-5 mins. I made sure the cap was on all the way and there is nothing between the M/C and the cap. Has anyone experienced the samething? Are you not having any leaks at all? I can hear a loud hissing noise as soon as I go beyond 5psi. Is my cap defective?
#68
on
I will try to make it tighter, but I can't really turn it further with any reasonable force. It feels like I will break something. Maybe adding some sort of gasket under the cap to provide a better seal? Has anyone tried that?
#70
on
The 1101 worked fine and held pressure for the whole day so I was able to check for leaks in my Stoptech brake system. I positioned the chain under the metal master cylinder, in front of the sensor wire and behind the hard brake line. I also made sure the cap was centered for a good seal. It worked perfectly and was very easy.
Personally I would say don't bother with the 1107 and just go with 1101. 1101 is a universal adapter and will work on many cars, so it's a better investment. I wish I didn't waste time and money getting the 1107 adapter.
#73
on
I love my motive........used it again today on my Nissan Xterra.......really needed it...been lazy and had not taken time to do this - been having spongy soft pedal that would drop way to far down to the floor board before braking.
I used my motive and got a lot of air out of my lines and fluid was dark. inspected for leaks and checked all seals and i think its just texas heat and age of fluid.
very strong feel now.....paired with wagner thermoquiet brake pads and my Xterra is stopping great.
-J
-J
#74
I did a little write up over on the UK site as well, using a very similar product to the Motive bleeder:
http://www.350z-uk.com/topic/96202-b...leeder-review/
wanderingstuden
01-28-2016 07:03 PM
