i broke the rear shock bolts! what to do??
#64
Snapped the bolt off today when doing rear strut tower bushings. Ended up cutting thr rest of the bolt off and drilling through. Then with shock out put a bolt with lock washer on top. The lock washer allows for tighting once you thread it down some. You do not need to drill a hole in the rear sway/tower that is in the trunk. Try this way before making big holes in your tower.
nizmo_0385 (08-29-2020)
08-06-2021 06:19 AM
