Developing a FAQ page for Suspension
#61
on
Originally Posted by ncparamedic
Not stupid..no sense in buying stuff your either not going to need or is for the wrong setup. Im by no means an expert. I have learned everything from these guys here, then just formulated my own opinion.
The Eibach sports are going to lower your car about 1.2" the pro kit will do it about 1". After 1" you begin loosing your camber and to correct that you will need the rear camber arms and Spc toe bolt and the front control arm (350EVO,Cusco(me), kenetix or stillen).
As for shocks, I like Tokico Dspec (thats what im getting).You have the 16 point ride adjustability. The marriage is good with the eibach pro kit combination. Im not sure about the eibach sportline. Ive read that Koni's are a good shock also. Its all about preference though. I hope this helps. Read old threads and ask around on the forum. If they blow you off as a newbie, the heck with them. Trust me i had the same questions and so did they..lol...
Fletch
#62
Prodigal Son
on
Heres the set up i got with prices. The eibach springs I have seen on ebay (search 350z eibach) for $193 + shipping.
Cusco front control arms - $395 shipped
SPC rear camber arms/toe bolt -$235 shipped
Eibach springs prokit - $220
Tokico shocks/struts - havent got yet but will in a couple..will probably spend $500 or so. So total that is $1350. I also bought me a set of Stillen sways and ordered new urathane bushings for $255 and then $40 for the bushings. Man thats not bad for nearly a whole suspension set up..
#63
on
I am sorry about this stupid question. Which springs are the best (Eibach Pro Kit, Tein S-Tech, or Hotchkis) if I want to lower my car without having camber problems?
#65
on
Body Tunning
I know this is not suspention but body Tuning directly relates to handeling and suspention. So how does the GTSPEC line of Chassis reenforcements improve over all handeling of higher (400+) horspower cars? Especialy with TT kits that require the removal of the front brace.
#66
on
adjusting the springs on the coilover
when i lower or raise my car do i also have to adjust the spring like loosen it or keep it the way it was... also do the springs have to be real tight to the upper mount or should i be able to turn the spring with my hand why the perch is tight im so lost.. ^_^
#67
#68
on
well the thing is i get a rattleing from my right rear and and i adjust the spring so it was tight enough were i could not move the spring with my hand while the perch was locked. the tighter i go the bouncyer it become i dunno if thats the was its supposed to be but i made the spring so i cant spin it around with my hand. lol im so lost with how to do this
#71
on
Are stiffer springs better? I was looking at Nismo T2 springs, and they have a spring rate of somewhere around 600+ lbs/inch. Does this mean that they're better on smooth roads w/ a adjustabile dampening shock like koni's or tokikos?
#72
Originally Posted by xirtam
If I get Tanabe Springs which lower my rear by 1.2 inch, do I need to get a camber kit? Or just a wheel realignment?
#73
Originally Posted by Soundeffects
When do the bumpstops need to be cut?
#74
Will
#75
Originally Posted by Resolute
Preferably never. If you're hitting your bumpstops and you cut them out, then you will simply bottom your suspension and risk damaging something. By bottoming out, I mean your suspension is compressing as far as physically possible, and hitting the bumpstops provides some cusshion when that happens. No bumpstops, no cushion. If you trim the bumpstops, then only trim them half way, and taper them so as to provide some progressive cushioning when your suspension runs out of travel. The ideal situation is to increase your spring rate to prevent your suspension from running out of travel to begin with. The lower your car, the higher the spring rate will need to be to keep you from maxing ouot your suspension travel.
#76
on
Spring Rates
I've noticed that the stock spring rates are higher in the rear;
OEM Front:314 Rear:342
and few coilover suspensions;
Nismo F:449 R:506 F+43% R+48% Transfers +5% roll stiffness to rear
Jic Flta-2 F:560 R:672 F+78% R+98% Transfers +20% roll stiffness to rear
Both known for track performance.
From the information that I have gathered the 350Z has understeer, which can be overcome in different modifications and combinations of modifications. Such as increasing tire width and inflation pressure in front only. Adding adjustable sway bars and changing them until the desired grip is achieved. Getting a performance differential like Quaife which will transfer more power to the tire with the most resistance/grip (the outside tire in a turn) compared to normal limited slip diffs which tend to make the car go straight. And then there is the spring rate to consider.
Like I mentioned at first the known track worthy suspensions tend to transfer roll stiffness to the rear unlike the majority of the others out there. I have also read that, “If the car is understeering, there is either too much wt transfer on the front outside tire or too little on the rear outside tire. A less stiff sway bar on the front will relieve some of the wt transferred to the outside tire, and a stiffer sway bar out back will increase the wt transferred to the rear outside tire.” To add to that I have also read that you should, “Set the car up via spring rate tuning first, then fine tune with sway bars. Sway bars are not meant to leverage large amount's of roll stiffness to overcome poor spring rate tuning, they are meant to fine tune at the limit balance/behavior on a already well sorted chassis.”
After digesting all of that, my question is this, wouldn’t it be better to select a suspension who’s spring rate adds roll stiffness to the rear like those mentioned above and add adjustable sway bars to fine tune, with maybe some of the other methods to help reduce understeer?
#77
https://my350z.com/forum/showthread....ght=truechoice
#78
Now the bad news: conventional theory doesn't make the best suspension on the Z. You always want to run as light a sway bar as possible for track use, since the bar will remove traction from the outside tire. Therefore, the conventional wisdom is to run as high a spring rate as possible on the driven end of the vehicle to keep both outside and inside tires as planted as possible for acceleration.
However, the Z has an abnormal amount of anti-squat and anti-dive in it's suspension. That rear "traction rod" that everyone pisses on about is part of the anti-squat design of the rear suspension and transfers a very high amount of weight to the rear on accel. This allows the Z to have traction for acceleration without using springs stiff enough to jar out teeth fillings. The problem is that it also means to keep the car flat through a turn it uses pretty big ant-roll bars. Because of the anti-squat engineered into the suspension, if you raise the spring rate too high out back you'll have wicked oversteer on acceleration out of a turn, and possible wheel hop if you're not careful. This is why convention doesn't always work every time.
The Z will do best with a lower rear springs rate than the front, just as the Unitech boys found out. Now, you can always cut off the mounts of the traction rod and the upper control arm, and lower the mounting points by re-welding them. I have seen this done. The Opera Performance Z is a good example. But is it worth all that effort? Not to most. Get the Truechoice suspension and have them sub in Koni 2812's for the dampers, and you'll have a more thoroughly tested and tried suspension than everyone else at the track.
Happy driving,
Will
#79
on
To answer your question: Yes, you understand perfectly the conventional wisdom for suspension tuning. And props on grasping the difference on handling a clutch LSD will make vs a geared unit like the Quaiffe. Very nice.
Happy driving,
Will
Happy driving,
Will
A few more questions.
What about front to rear balance, if the rear is that much softer a lot of weight will transfer to the rear during acceleration and cause the rear to squat upsetting the balance of the car, so would you corner weight the car with a higher percentage forward like 55/45 or greater to retain a close to 50/50 balance under accel, or do you really want that much more weight in the rear?
Also what about roll stiffness, since so much is being transferred to the front wouldn't that require a stronger rear anti-roll bar to keep the rear planted or is the structure of the car rigid enough that the added stiffness in the front will keep the car flat and from rolling too much?
One more, with a staggered set up with wider tires in the rear and a diff like the Quaife, is it still recommended to soften up the rear? Or would you want to keep the spring rates equal front & rear so not to create more oversteer?
I want it to be fairly neutral handling with mild understeer at the limit, with power on oversteer, mostly driven on the street and see some track use hopefully. I am terribly analytical about everything, over thinking stuff to death, it's just, what i do.
Thanks
#80
Great reply.
The weight transfer taking place in a car is only dictated by the hight of the center of gravity in the car, the wheelbase and track width of the car, and the over all weight and its distribution in the car.
Spring rates and anti-squat, roll bars, etc.. do NOT alter the weight transfer taking place. They alter the contact patch, camber curves, and effective wheel rates to improve or otherwise alter available traction at their respective tire(s).
Keeping this in mind, your corner weights should have an equal wedge front to rear. That is, they should have equal weight totals in a diagonal pattern, FR to RL, etc.. There is no point in increasing spring pre-load to compensate for weight transfer due to a relatively softer spring rate out back, since spring rates do not affect weight transfer.
Thanks
Thanks
Will
