ExoticAir 4wheelcup suspension install, oem rear location, pics n details!
Old 07-04-2014, 10:44 AM
  #41
Kwame
Kwame's Avatar
I like the new location.
How loud is your compressor.
Old 07-04-2014, 01:31 PM
  #42
Cux350z
hatersgonnahate
Cux350z's Avatar
Havent run it yet. Since I upsized the compressor I need to run a parallel wire and larger relay. Should be quiet since it is sitting on a huge block of foam.
Old 07-19-2014, 10:50 AM
  #43
Cux350z
hatersgonnahate
Cux350z's Avatar
video of the sound. Seems loud. I may add some additional noise canceling foam.
Ran dual 14awg wires to it instead of a 10awg. Reason being is that i already had a single 14awg to my old compressor and 14awg was cheaper and easier to get in the right length.
Old 04-29-2015, 10:39 AM
  #44
ipodhustle
ipodhustle's Avatar
back from the dead lol
how is this working for you so far?
also for your compressor:
have you looked into an Air Zenith ob2?
specs look bada$$ and supposedly works twice as fast as a viair 400c or something like that
Old 04-29-2015, 03:35 PM
  #45
Cux350z
hatersgonnahate
Cux350z's Avatar
Its working great. gets me in and out of driveways and such just like i needed it to.
I did upgrade my compressor once which really helped. The main thing would be to get a 2gal tank or 1 gallon.
That air zenith is a beast...probably meant for bags.
Old 01-20-2016, 11:27 AM
  #46
bmccann101
bmccann101's Avatar
im back.. im thinkning of switching back to static w cups vs my UAS bag set up.. i want to ride more linear and stiff when low... maybe i missed it, but CUX350z.... what spring type and perch/mount did you use for the rear?
kg?
Also curious how low you can set ride height w your rear set up.. thanks! Id PM you, but its good info to add to the thread too
Old 01-31-2016, 04:08 PM
  #47
Cux350z
hatersgonnahate
Cux350z's Avatar
The rear cups slide over the BC adjusters. I had Exotic Air mill the cups out. Luckily the inner sleeve was big enough to allow it. Using the threaded adjuster I can set ride height. Pretty sure I have it bottomed out all the way.
Swift 65mm springs..cannot remember the KG or the length since i bought multiple sets. The goal was to have enough travel to not bottom out and still have a decent ride height.
Old 08-22-2016, 05:29 PM
  #48
bmccann101
bmccann101's Avatar
ever since reading this thread, I had started researching.. ended up with a (front only) air cup kit on a new set of fantastic dampers form Fortune.
Not to thread jack of course, just didn't feel it deserved a new thread lol. Fortune makes a cup system, and now so does Stance.. for those stumbling upon this who area actually searching the forum ( good boy)... my friend Maarten in Denmark offers piece meal, build your own system air cup components including electronic valves for cheap at "stance-parts" .com
but it seems that suspension companies have FINALLY started offering "front end lift" cup systems, same as on any exotic sports car.
( I think most of those have a small engine driven air pump and don't use any reserv4e tanks.. hence they are slow as *****).
Hoping to have at least the static installation done soon, and the Accuair is already sold.
sales@czp
Suspension
54
01-17-2018 09:24 PM
BEBO'S ZEE
06-07-2016 07:48 AM
DarkCreep
10-17-2015 11:50 PM
CJs_Z33
09-18-2015 12:06 PM
ThreeFiveZero Z
09-12-2015 04:33 PM
Quick Reply: ExoticAir 4wheelcup suspension install, oem rear location, pics n details!
