Whiteline Rear Differential Bushing Review
on
I've checked ebay, none of the removal tools seem to list the dimensions of the components which makes buying them a crap shoot. I've mailed two sellers, will see if they come back. Otherwise I'll have to by a recip saw..
Yes you definitely have to do a little digging...the sellers of those used OTC/ROTUNDA factory tools hardly list specs, but they will list the intended make/model/piece the part is for. Going to sound a little crazy but you can also approximate the size of the cup using something to reference in the picture...maybe the hole in the middle. As long as you err on the size of too large youll be fine.
Heres a little help for you (since trial and error is a little more difficult shipping to the UK):
http://www.ebay.com/itm/Rotunda-Ford-Explorer-Factory-Tool-Set-FREE-SHIPPING-/151087931443?hash=item232d8ae033&item=151087931443&pt=Motors_Automotive_Tools&vxp=mtr
That receiving cup will clear the OD of the outer sleeve in the subframe, but will rest a bit awkwardly on the two large weld points on the subframe face. This wont cause any damage, just leave a slight flat spot on each weld (cant see them on the inside of the subframe anyway).
Also the bushing will bottom out in the receiving cup, but will be far enough that you can take it the rest of the way out with a hammer.
The driver is the perfect size.
Don't forget to lube the threaded shaft with moly grease and take breaks to let everything cool down. I was very impressed with the tool.
Odd question. I watched the linked Zgarage video on removing the diff and installing the bushings. Why did he mark the axels and drive shaft with the diff? I've swapped diffs in and out of cars and they don't need to line up exactly how they were. If I have my axel rotated 180 or anything it won't matter. As long as it all bolts back together.
This was informative. Thank you.
Anyway, per the service manual, you mark the original orientation of the driveshaft and axles so they can be re-assembled the same way. If you didn't have vibration before, you won't after re-assembling. If you install them with a different orientation, there's a chance you might introduce a new vibration due to slight imbalance of the mating parts.
08-06-2021 06:19 AM
04-04-2016 07:52 AM
