CZP Brake Lines Suck
EDIT: Turns out that CZP no longer makes these lines, so I can't say whether it's theirs or Technafit's lines that failed. Coz has since contacted me to help make things right, and in no way was I originally bashing Coz - just the brake lines that I was using and how frustrated/unsatisfied I am with them.
Background story: I ordered the CZP G37 Retrofit brake kit for my 350Z when the kit pretty much first came out, several years ago. My kit came with the G37 calipers, CZP brackets, StopTech slotted rotors, Hawk Pads, and CZP Teflon coated SS brake lines.
SINCE purchasing and installing the kit, my drivers side rear brake line leaked and had to be replaced with a new one. Luckily, this first time, it was not so severe and I was even able to take photos and a video of the brake fluid leaking from the line. I sent these to CZP, and they replaced my rear lines free of charge. I decided to go ahead and replace the passenger side rear when the new lines arrived just to keep both sides in check, and in case there had been any revision to the design.
Not even maybe a year later, the passenger side rear line completely deteriorated at the end that screws to the hard line coupler. This time there was no possibility of driving the car what-so-ever, because almost all of the fluid leaked out of where the coupler split.. I was able to salvage a rear brake line from my stock brakes and use this as a temporary solution until I could either replace all of the lines, or just order a whole new brake kit and trash the CZP junk.
Well two weeks ago, here I am driving on the highway and getting ready to slow down for my exit. Hit the brakes to start slowing down. . . .Brief thump. . . .Pedal goes to the floor. . . .And there I am doing 60MPH in the exit lane with no brakes. I'm fkn glad that I'm smart enough to know how to downshift, and pump my E-Brake that allowed me to safely slow down and get off the exit without damaging my car, myself, or any others or their cars around me. I knew right away that it was these piece of $h!t CZP Brake lines. I stopped the car in a parking lot, and sure enough there was brake fluid all over my passenger side front wheel. One of the lines burst.
I ordered Z1 Motorsports lines last week, and they came within two days. Put them on Saturday night, and everything went as smooth as could be. While removing the old CZP line from the front, I took a look at what happened. CZP makes their lines so short, and with insufficient bracketing, that the lines rub the knuckle. The lines are too short to correctly clear all suspension components, and end up rubbing through the teflon coating, and eating at the SS lines. I wish I had saved the lines, or at least taken a photo, and been able to send them back to CZP to show them how dangerous their design is. Literally you could see how the internals of the line had burst open through the hole that had been rubbed into the side.
I'm just sick of dealing with a bull$h!t product, and I hope that others can learn from my own mishap. CZP has lost my business forever, and I hope that you strongly consider this review before purchasing any parts that are "made by them."
/RANT
/RANT
Pics, I wonder if they were properly routed.
"I wish I had saved the lines, or at least taken a photo, and been able to send them back to CZP to show them how dangerous their design is."
I might have some old photos from when I originally put them on. . .
They were properly routed. And honestly there's really no other way to route them because they're so short. Also their lines only came with one bracket to mount to either the knuckle or the strut, rather than both.
I don't have any of the fronts, but here's the original one that leaked and they sent me replacements. The next two completely came apart. And for the rear to do what it did, makes no sense. There was no rubbing in the rear - It simply just came apart.
VIDEO:
VIDEO:
Administrator
I did a Google CZP search for similar problems, but didn't find any through 3 pages of search results. I was curious myself as to what could have been the problem. It didn't make sense to me. But like others have said, we're glad the OP is ok. Brake failure is not cool...
I hate when vendors try to hide stuff. Sure some things don't need to be public info but in a thread like this we should at least be able to see what is being done to fix the situation.
We get a big long speech/rant about a defective part, people start slinging negative comments, the vendor pops in to say they sent the OP a PM and nobody ever finds out how it ends.
Send pics.
Send pics.
*CZP/Coz have been very good to work with; I've done full brake, clutch/flywheel kits from them and they are a professional outfit!
So first I will say that I bought my Akebono kit very lightly used so I have never dealt with CZP at all, but I am under the impression that these are the same lines that are being discussed here. I live in Canada and these have been on my car for approx 1 yr and 10,000miles. Driven in all weather conditions. I think the winter (salt) did a number on the hardware provided with the lines. The previous owner claimed only 500miles of use.
In this first picture, you will see how the line creates a sharp angle after passing through the bracket on the strut, which has caused the coating to rip and come off in that section. I experimented with positioning the bracket differently but this was the best that I could come up with to put the least amount of stress on the line.
In this second picture, you can see how the line has been rubbing against the spindle and actually polished it a bit! Suprisingly, the teflon coating in this area has not ripped through. That little bunch you see near the bracket is how the whole sheath has moved down from where it ripped at the strut bracket.
You can also see how the line rests on top of the caliper adapter bracket. Once again, this is the best route I could do because if you change the angle of the line as it goes into the caliper, you would get more slack but the line would be pushing right on the caliper bracket bolt.
Now if you noticed the orientation of the brackets that come pre-attached to the lines, you will see that if you were able to flip the spindle bracket the other way, you may end up with more clearance.
"Well then why didn't you swap the lines from left to right side of car!?"
Well you see, the strut mount bracket is the right way. If you swapped the left and right lines, the strut mount bracket will definitely be the wrong way and just rub even more.
So, bottom line, I don't think the lines are a perfect fit in the front. It could be that the mounting solutions they provide are not proper. Better brackets could probably help resolve this issue.
In the rear, the lines are fit perfect and there is no issues, so I didn't take pics of them.
EDIT: I see that another company makes a "premium" SS brake line upgrade with OEM type mounting blocks. Obviously this type of mounting block is important to prevent stretching/rubbing.
There is something about the OP’s story I don’t understand. I’ve been told that all brake systems in use over the past 50 or so years have dual circuits in the master cylinder, each one powering two of the four wheel brakes. In the event of a component failure and loss of fluid, the pedal will drop an inch or two (but not to the floor) and still engage two of the four wheels brakes. Usually one front and one rear in a diagonal fashion.
Why did the loss of only one line cause the total loss of all brakes?
