Cusco Front Negative Camber Arms Settings?
Hey Guys,
I just picked up a set of Cusco front arms, that didn't come with any of the original packaging or paperwork.
After playing with the ball joint mounts last night, I think I got the settings figured out since there's +4mm, Stock, -4mm, -8mm, and -12mm. I was told that each 4mm movement is about a 0.5 degree adjustment in camber.
Just curious if anyone has the actual setting diagrams from Cusco on the mounting locations for the ball joint mount? Would be super helpful - I looked on Cusco's site (both english and japanese) and wasn't able to find anything.
Thanks in advance!
Thanks in advance!
How much camber are you looking to get?
Put the car on level ground and grab a level, put the level against the bottom of the wheel and then set the camber so you have about 40mm between the level and the same spot at the top of the wheel. This will give you about -3.3 camber.
Or you can look up the equations and do the math to get an exact number.
They actually have 5 settings - Cusco's site lies haha
Trust me, I was physically playing with the different set-ups last night plus Z1 runs these on their shop car, and I would trust what they say:
http://www.z1auto.com/prodmore.asp?m...0z&prodid=1288
All told, these arms have 5 positions: +4mm vs stock, stock, -4mm from stock, -8mm from stock, -12mm from stock.
Dark Knight
Wheels Tires
11-11-2015 08:40 PM
350Z Project X
Suspension
10-10-2015 09:23 AM
