High speed braking vibrations
Please help me determine the cause of my high speed vibrations as best you can.
My 2006 begins to shake at medium braking power at high (freeway) speeds.
Things to note:
1. Feels like the vibrations originate from the front
2. Car in otherwise good mechanical condition
3. I greased up my pads to eliminate brake squeal (no, not the part that touches the rotor)
4. Mechanic found warped rotor bolts in rear wheel (told me it happens from impact)(pre-owned vehicle)
Is it possible that the brake pad grease is too slippery and causing the pads to slip too much?
Is it possible the front bolts are also warped and are the cause of these vibrations?
Things to note:
^^^ x2. Quality replacements: http://centriccatalog.com/
Find part number, copy/pasta in Amazon search, order rotors. Done.
And "warped rotor bolts", your mechanic is a retard.
The only thing I could think of being referred to as a "rotor bolt" are the ones found from factory on the front rotors: https://my350z.com/forum/7149681-post14.html
on
lol. Yeah, he used "rotor bolts"..... I'm not sure why. Maybe he is used to dealing with lay-people so he used that word on me lol.
Anyways....the general consensus is that the rotors are warped.... how the hell does that happen? I thought it only happened under extreme heat and then rapid cooling?
I don't remember having this issue right when I bought the car, and I really can't think of a circumstance that would warp them... I don't even track the car.
on
They warp over time. Coming off of an interstate ramp at 80 and slowing to 0 generates a lot of heat. More than you probably think. They just warp. It isn't something you did wrong. The rotors are probably older and need replacing anyways.
single me out because i'm the only one who said it was warped rotors... (the most likely cause based on your description).
