Someone help with camber please!
Hey so I just got new wheels and tires
19x11" +15 rears with a 305 and 19x9.5" fronts with a 255.. Pretty meaty
(will be posting pics soon!)
I have about 3/4 inch of poke in the rear and I'm still stock height
What I want to know is how much camber I need to not poke once I get camber arms? I'm hoping under 3 degrees
I'm really hoping someone can figure this out for me
Thanks!
Thanks!
Thanks!
Thanks!
Toasty
Thanks!
Thanks!
-You're running a 305/30/19 rear tire
-You're currently at the factory camber spec of -1.8 degrees
-The 3/4" measurement you came up with is accurate
You will need about -5.1 degrees of camber to close that 3/4" gap (in other words, an additional 3.3 degrees of negative camber).
Good luck
Edit: -5.086 degrees if you want to be really accurate.
Thanks!
Thanks!
Toasty
Comparatively, yeah, the 255 on the 9.5 has less excess tire than the 305 on an 11. I was just speaking in general terms that a 255 on a 9.5 isn't considered stretched. I dont know exactly what the technical definition of "stretched" is (or if one even exists), but personally I start considering a tire stretched when the width of the tire is less than the width of the wheel.
Thank you Phenom for answering the question haha
5 degrees of camber is way too much so I think I'm going to see if I can mill the backs at all.. Anyone know how much I can safely mill them?
I know not everyone is going to like the color of the wheels but that's alright with me..
I like them a lot.
Also wish that I had gotten a less aggressive offset
but too late for that.
I wanted 265 front but these tires don't come in 265 unfortunately
I like them a lot.
08-06-2021 06:19 AM
350Z Project X
Suspension
10-10-2015 09:23 AM
