Z and g front upper control arms suck
Old 09-15-2014, 08:33 AM
AARONHL
AARONHL's Avatar
Default Z and g front upper control arms suck
So my g35 has been lowered for a while now, was using SPC upper front arms, but found those too hard to dial in by myself unless they were done at the alignment shop. The sliding bolt is way too touchy.
Next I tried the Kinetix front upper control arms, they were awesome for the first 5 months. Easy to adjust because you could reference where you started by the number of turns on the ball joint. Then the Crunching and Creaking noises started going 0-10mph when starting and stopping. Lubing the bushings does not help. The ball joint is also hitting the inside of the fender so I had to hammer that out. Still need a little more positive so more hammering is required.
Now I am stuck, don't know which arm to go to now. The SPL arms for $700 are way too much. But worth it?
What other arm should I try??????????
What I am thinking of doing is adding a hard bushing to the Kinetic. Or a bushing similar to the SPC. But one of the reason is ditched SPC was because of the bushings it used.
Old 09-15-2014, 08:51 AM
jdmfetish
jdmfetish's Avatar
i have 2006 350z
19 x 9.5 work vsxx 225-35-19
19 x 11 work vsxx 245-35-19
megan coilovers
2 " drop F & R
i had ichiba BS front upper control arms and blown bushings
i put SPL front upper control arms last month with SPL front tie rod ends
WINNING
Old 09-15-2014, 08:54 AM
AdvanZ33
Senior Super Moderator
AdvanZ33's Avatar
No problems with Cusco thus far.
Old 09-15-2014, 10:52 AM
AARONHL
AARONHL's Avatar
Speaking of the SPL tie rod ends, they look two-sided. What makes them different than OEM, or what makes them more adjustable than OEM?
I will try to look at as many upper control arms as I can to see whats up
Old 09-15-2014, 12:56 PM
guitman32
guitman32's Avatar
What about replacing the bushings in the Kinetix...if you arent already set on new arms of course.
Old 09-16-2014, 09:47 PM
AARONHL
AARONHL's Avatar
Yea I could do that but I think it's the rod end on the arm that is making the CRUNCHING sounds...the red bushings have so much silicone grease on them
Old 09-17-2014, 12:07 AM
NoQuestionZ
NoQuestionZ's Avatar
What version of the Kinetix do you have? I have the Silver Version 2 with the red 1/2 boot. My driver's side has a "knock" and I'm thinking of updating to the black full boot one for $30 on their site.
Old 09-17-2014, 12:48 PM
AARONHL
AARONHL's Avatar
I have the Silver ones with red bushings and the full black boot over the rod end. I still think it's the rod end making the crunching noises
Old 09-17-2014, 03:02 PM
guitman32
guitman32's Avatar
So the noise seems like its coming from the ball joint on the A-arm? Not sure what you mean by "rod end."
If so you can just get a new ball joint... https://conceptzperformance.com/Cart...on.php?II=7976
Old 09-19-2014, 11:10 AM
AARONHL
AARONHL's Avatar
That is the part I am talking about. Technically it may be a rod end, a ball joint is only one sided- has a base and a nut on top. They just list is as a ball joint.
The arms are very noisy within a year...would hate to get a new joint for it and have the problem come back. I have seen people here spray lithium grease in the black boot and it seemed to help with the noise. Every time I step on the gas from a red light of stop sign, there is a crunching noise. Sometimes it come from the right, sometimes the left
Old 09-19-2014, 02:21 PM
BH!
BH!'s Avatar
Just go with SPL. They are the nicest suspension component I have ever owned. Mine are silent so far and they are the smallest profile arm available so no more slamming your sheet metal. As for setting the camber, just make sure you use equal amounts of shims on each side, any difference that shows up on the alignment rack is negligible.
Old 09-20-2014, 04:24 AM
2000atlanticgt
2000atlanticgt's Avatar
I sprayed some white lithium grease under the black boot coating the rod end, only did this one time over 10,000 miles ago and mine have been noise free from the day I did that.
Old 09-20-2014, 08:21 AM
guitman32
guitman32's Avatar
Just looked at the kinetix joint under the boot, I agree technically it is a spherical "rod end!"
For $60 it seems like an easy fix. There is NOTHING more annoying and cringe inducing than the sound of a crunchy ball joint!
Obadabot
06-18-2023 11:31 PM
350Z Project X
Suspension
10-10-2015 09:23 AM
Quick Reply: Z and g front upper control arms suck
