VDC error after Brembo upgrade
Hey guys, normally I just figure this crap out on my own but I wanted to see if anyone had any insight as to what's going on.
1) Rebuilt Brembos I bought just to be sure seals were good
2) Swapped out my OEM 2005 floating calipers to the OEM Brembos
3) No leaks but took FOREVER to bleed because I let all fluid drain out of lines when I took old calipers off and air got in master cylinder
4) Finally got everything to bleed, pedal feels better than ever, again - no leaks. I've checked everything multiple times over the course of a few weeks
5) Pads and rotors still have a lot of life, 90% maybe
6) Everything was fine for 2~3 days after install
7) Go to start up on cold morning, VDC OFF and SLIP lights come on before moving anywhere, E-Brake was still engaged
8) Been a couple weeks now and VDC is still failing
9) Fluid in reservoir is right at MAX line and has not changed at all (again, no leaks)
10) ABS works fine, BRAKE light is NOT on
11) Unplugged brake fluid level sensor to check connection and there was some brake fluid in the connector
So - there's the run down. My initial thought is that the brake fluid sensor is failing telling the computer that fluid is low and thus shutting down the system. Other than that I have no clue what it could be but I'm open to any ideas.
Cam sensor maybe
Wheel speed detector
Bad fluid level sensor , easily bypassed to check it out.
Wheel speed sensors - remember, the lights came on prior to the car moving at all. I don't think it would register as "bad" if it hadn't moved. Rear wheels register a speed individually btw, haven't checked the fronts yet.
Cam sensor - no SES code was thrown. I thought I read that cam sensor will throw an SES code as well.
Bad Fluid Level Sensor - how to bypass for inspection?
on
I just got done with the brembo swap as well... Mine was a train wreck too. At least you had better luck then I did. Let us know what you find out.
As Terrasmak said, by pass your fluid level switch. When i was installing my brembos and had just finished bleeding, I turned the car on while it was still on jack stands in the front and the VDC off / SLIP lights came on. Did a quick search and read that happens when the fluid level switch doesn't make. Lowered the car down and started the car again, both lights were off. Good Luck.
