Help needed: SWIFT SPRINGS part numbers for my BC COILOVERS BR TYPE
Wanting to upgrade the springs on my BC COILOVERS BR TYPE with SWIFT SPRINGS.
Anyone know the part number for the SWIFT SPRINGS that fit these coilovers?
Also should i keep the same spring rate that came with these coilovers, or go one up. Ive read you can go one step up on the spring rates and the car will ride the same as the original spring rate, yet perform as the actual spring rate.
Measure the inside diameter and length of the springs. Take note of the spring rate, and contact any vendor that sells Swift Springs. Give them the information, and let them send you the right springs. Swift doesn't necessarily make springs for different coilovers. Most vendors just add them as an extra if you want them.
As far as keeping your spring rate, try it first if you want. Most of the cheap coils wll be fine if you go up 1kg, but your best bet is to revalve them for the different rate. It really depends on you.
Contact Mike at Corner 3 garage, I believe they deal with BC and they have a great working relationship with Swift. Between the two, they will get you exactly what you need.
08-06-2021 06:19 AM
CFAUVEL
10-01-2015 03:20 PM
