unusual movement
Old 11-12-2014, 08:20 PM
JDMStanced
JDMStanced's Avatar
Default unusual movement
Hi
couple of month ago i went to get the alignment done.
the guy told me that there is unusual movement when turning steeting.
When turning steering to the right, the right side of the car lifts up. And vice versa. Now that i know it, i can really tell that one side lifts up in the car.
Also its visible from the rear.
He said parts may have been installed wrong but not sure..
I have spl solid compression arm, es suspension bushings, stance true type coilover, adjustable endlinks and sway bars.what do you guys think?
Old 11-12-2014, 08:31 PM
Emski
Emski's Avatar
First of all, STOP SAYING "TURNING STEERING".
What you describe is just body roll. You need to be more descriptive. Do you mean ONE wheel is lifting off the ground during cornering? If so, one bar might be set up way too stiff relative to the other.
Old 11-12-2014, 09:30 PM
JDMStanced
JDMStanced's Avatar
Im talking about when the car is not moving.Either whole right side rises up as turning steering wheel to the right or vice versa.
Old 11-13-2014, 05:03 AM
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,290 Likes on 894 Posts
OP might be referring to static bump steer. Do some research and figure it out.
alexlo
07-02-2003 02:51 PM
raymanZ
01-16-2003 08:06 PM
^Tyr
11-11-2002 06:17 PM
Samurai
10-25-2002 08:27 PM
Quick Reply: unusual movement
