HELP!!! Sway Bar End Link Stuck!
Old 01-28-2015, 04:50 PM
Z1NONLY
Z1NONLY's Avatar
I would get the whole front end off of the ground so that the sway bar has no tension. Then remove the endlink from the other side. This should allow you to manipulate the sway bar up or down to get the angle right and remove the end link from the problem side. (You may have better luck moving the control arm then too)
Old 01-28-2015, 04:56 PM
terrasmak's Avatar
Received 2,284 Likes on 1,646 Posts
Remove the other sides lower shock mount bolt !!!!!!! The sway bar is twisted cause the side with the new coilover is shorter.
You have about 700 pounds of force twisting the sway right now. You need to relieve the force before the bolt comes out.
You tried to jack it, jack it more. As your listing it from the ball joint watch the bolt when you see the bolt move , your golden. You may even lift the car off the jack stand when doing this.
Old 01-31-2015, 06:36 PM
Knifey McStabb
Knifey McStabb's Avatar
Thx guys! I removed the other sides shock mount bolt and loosened the end link. That allowed me to move the sway bar enough to free the bolt on the other side. Frustrating situation but at least I learned something I guess.
Old 01-31-2015, 07:11 PM
terrasmak's Avatar
There is a reason I knew the answer. Been there , done that. But it only set me back 10 minutes.
Old 02-06-2015, 05:54 PM
Knifey McStabb
It's all good. Car is done. Toe and camber arms are installed and the car is aligned. All done for now. Thanks for the help.
Old 10-03-2021, 04:47 PM
350zleolb
350zleolb's Avatar
Remove the other side lower shock mount bolt !!!!!!! The sway bar is twisted cause the side with the new coilover is shorter.
Hi, so I know this thread is a couple of years old but I seem to be having the same problem as this guy, the end link is stuck on the LCA, I’ve also removed the bolt that goes on the inside of the LCA so that might make my situation worse, spent a good part of the afternoon trying to find a way to put it back together but no luck. I’m willing to try what you said but Can someone tell me which one exactly is the lower shock mount bolt?
Old 10-03-2021, 08:22 PM
terrasmak's Avatar
Here you go
Old 10-03-2021, 11:20 PM
350zleolb
350zleolb's Avatar
Here you go
Would that be the banana arm bolt?
Old 10-04-2021, 02:13 PM
350zleolb
350zleolb's Avatar
So I tried loosing the bolt on the other side but now the nut and the bolt are turning together instead of the nut turning in the bolt, any ideas on what else I can do?
Here you go
Old 10-04-2021, 02:19 PM
travlee
Master
travlee's Avatar
Received 9,047 Likes on 6,513 Posts
Get a wrench......jeebus
08-06-2021 06:19 AM
04-04-2016 07:52 AM
350Z Project X
Suspension
10-10-2015 09:23 AM
pr_350z
10-01-2015 05:03 PM
Tochigi_236
09-27-2015 03:40 PM
Quick Reply: HELP!!! Sway Bar End Link Stuck!
