Need help: Vibration/Clunk Issue
Old 03-31-2015, 05:12 PM
SFerg
SFerg's Avatar
Default Need help: Vibration/Clunk Issue
So I purchased my car a little under a year ago
350z 2005 Enthusiast 118k Miles
There are currently no suspension mods. (Don't flame, work in progress)
From the front end I have a clunk. Going over bumps, ripples, any uneven surface. Like a gnarly clunk. I can hear it inside the cabin from the front driver side, and front passenger side.
What I have done: ALL front suspension bushings with polyurethane bushings, checked strut mounts Good, checked engine mounts. Good
Separate, possibly related issue. At 55mph+ I get a vibration in my steering wheel, a violent vibration.
This issue does not occur with my stock wheels
This issue occurs with my BMW 7 series + 25mm adapters.
What I have done: Swapped all 4 wheels and adapters with my buddies, issue was still persistent (rules out my wheels/adapters)
Possible fixes: Replace rack and pinion & tie rods, replace ball joints, replace sway bar bushings, change power steering pump.
I am really at a loss here. Any help would be greatly appreciated.
Old 03-31-2015, 05:22 PM
travlee
Master
travlee's Avatar
Received 9,043 Likes on 6,509 Posts
did you do the lower inner control arm bushings?
Old 03-31-2015, 05:23 PM
SFerg
SFerg's Avatar
OH yeah. I did them real nice and good and pretty like. Didn't fix anything.
Old 03-31-2015, 05:27 PM
travlee
Master
travlee's Avatar
hmmmm, let me rack my brain
Old 04-03-2015, 06:02 AM
SFerg
SFerg's Avatar
bump
Old 04-03-2015, 03:22 PM
kilogram
kilogram's Avatar
Wheel bearings? Lift the wheel off the ground and see if there's any vertical play. You'd also notice a kind of roaring sound when the offending wheel is loaded for a turn. (bad left front roars on right turns, bad right roars on lefties)
Old 04-04-2015, 06:23 AM
i8acobra
i8acobra's Avatar
Received 1,265 Likes on 1,014 Posts
Bolt on a set of wheels without any spacers. Pretty sure that will fix it if there really are no bushing issues.
Old 04-04-2015, 07:40 PM
SFerg
SFerg's Avatar
Gonna get my wheels redrilled and hope for the best.
Old 04-07-2015, 10:12 AM
cincysilvias14
cincysilvias14's Avatar
mines doing the same thing. only braking do i really notice it, or the rough surfaces (if anyone lives in or by cincinnati understands)
Old 04-07-2015, 10:35 PM
SFerg
SFerg's Avatar
ISSUE IS FIXED! Turned out to be sway bar bushings.
When braking, this sounds like it could possibly be your rotors.
Old 04-10-2015, 07:49 AM
rustyschopshop
rustyschopshop's Avatar
sway bar bushings should have nothign to do with vibration though, I would get your front wheels re-balanced.
apex locator
07-23-2021 02:27 AM
11-09-2020 10:27 AM
sherm
04-11-2020 05:21 PM
350z82
10-01-2015 06:25 PM
Depravity
10-01-2015 04:49 PM
Quick Reply: Need help: Vibration/Clunk Issue
