Akebono for 08 350Z Base w/ Grand Touring wheels
Just my luck.
The wheels DO NOT clear the brakes! Unfortunately we found out at about the time the shop had to close so my only car is sitting on a lift at the shop until I can figure this out.
From what I could tell the caliper was only contacting the inside of the barrel slightly; at the corner.
The biggest question I have now is: can I have them "safely" grind off 1-2mm max? Will this compromise the integrity of the brakes?
I would have taken some pictures but I had alot going through my head when they gave me the bad news; I will snap some in the morning.
I will once again scour the forum for information on grinding on them; if anyone can chime in I really need your help. Thanks guys.
So this begs the question - what changed from '07 to '08 with these rims? Or is this a result of the mounting brackets for the calipers? I've got the CZP ones. Maybe there is a slight difference in the caliper? I've got the standard silver Infinity ones.
I'll see if I can get better pictures of mine... but I doubled checked last night and I can just get the keys to the car in between the barrel and the caliper on the tight end. Maybe the gap is only 1-2 mm instead of the 3-5 mm I guesstimated.
At this point the ONLY difference between our cars is mine is an '03. Did Nissan relocate the brakes mounting point? I wouldn't think so as that would mess up the pad sweep on the rotors But if it moved slightly that could be enough.
Could it really be just the power coating that is hitting? If so that means these brakes are just an RCH away from the barrel
Toasty
That is what I have as well. I'm pretty sure CZP takes the Infinity ones and powered coats them. The Nissan branded ones are more expensive for no reason other then they are red (ohhhh pretty) and for the Z (ohhhh faster)
I wonder if there's enough float in thru holes of the caliper adapter bracket that it can affect the position of the caliper by a few mm. That would be a question for CZP/whoever machined their adapters to find out what tolerances they're sticking to.
I'm actually really curious about what's going on here.
UPDATE:
The only feasible solution was to get new wheels.
I went for black Enkei RPF1's (18x9.5+15 square) and to my relief they cleared the calipers.. just enough.
Car looks awesome which is great but now I have to do something about my rear fenders because it rubs. Currently on 275/40/18. I've never rolled fenders before but it looks to me that I may need them pulled a bit as well.. meh.
I will update with pictures of everything when I am able.
I'm pretty puzzled too
Toasty
UPDATE:
Oh yeah, where did you buy those wheels that they came that fast?
i feel like many ppl in this thread confused the touring v2 wheels with the rays v2 wheels that the OP are talking about...
touring v2 wheels fit just right, but the rays v2 is a different story :/
Just for reference I am also using the CZP kit with stoptech components.
As far as the wheel source, I called a few shops near me and luckily one had the set in stock so I was able to pick them up. It was over an hour drive each way but I was determined to get my damn car back haha.
Thanks for the advice on the rolling of the rear fenders.
I now have to deal with yet another issue; you try to set up your car properly and its nothing but headaches along the way.
While the car was in the shop they noticed my driver side rear shock was leaking. I got under the lift and checked it out; the shock was filthy and the other rear shock spotless. The KW v3's were bought brand new from CZP only 8 months ago and installed at Stillen (authorized installer, fackin expensive). With only 10k miles of normal street use I have to deal with this ****. Was in the garage last night just checking out the cars updates (sexy as hell) and noticed that on the rear side with the leaky shock the car actually has 3-6mm LESS fender gap.. WTF.
I went on their website last night and saw they have a 5 year warranty on them if installed at an authorized dealer. Called them today and they want me to send them the shock so they can rebuild it, only problem is, its my ONLY car.
So I'm trying to figure this out. They want me to get a rental car for likely upwards of a month, and why.. because they're product FAILED after 8 months of commuting?! If I'm going to be shelling out that much money I may as well just buy a new damn shock from them. I'm just beside myself right now. I love the product but damn, I thought they made decent stuff.
Thoughts?
Thoughts?
Toasty
Thoughts?
Thoughts?
I have the Z1 kit. I wonder if it makes a difference compared to the CZP.
This thread is making me nervous. I really hope they fit. I have both the V1 and V2 touring wheels, both 18"
#38
Still don't understand why mine fit and his don't, we both had '07 V2 Touring wheel and the CZP kit, the only difference is my car is an '03 so maybe Nissan changed the mounting points on later models ever so slightly?
#40
The nismo 18/19 WILL NOT clear the inside of the barrel, it will touch.
Only options that presented themselves to me:
1) Shave/grind on the calipers
2) Get proper wheels. (recommended)
