Lower Control Arm Ball Joints Help
What's up guys. Had my Z corner balanced and aligned at West End Alignment two days ago and they pointed out that my driver side lower control arm ball joint needs replacing.
So, the question is should I just press out and install new ball joints OR just buy a new control arm with the ball joint already installed.
I found that CZP sells the ball joints for around $40 each but I can't find any reviews on them.
Moog sells the complete lower control arm with bushings and ball joints already pressed in for around $75 each side.
What would be the best way to do this, thanks!
Your post needs clarification...there is no ball joint on the lower control arm...that one is in the knuckle itself, and is serviceable on its own.
There IS a ball joint in the lower compression arm, but that one is not serviceable, and you must buy a complete replacement arm to replace that ball joint.
Are you experiencing creaking or knocking from that side of the suspension? If not, the ball joint is probably fine, just the boot is cracked/leaking grease, which is very common.
Make sure you verify this, as the best ball joints available are usually OEM ball joints. Aftermarket joints tend to have service intervals that are MUCH shorter than OEM (even from companies like Raybestos and Moog, as has been my personal experience).
Needs replacing because the shop that I had replace my oem ones apparentely installed these ones wrong, it moves around.
I just replaced the ball joint itself. Drivers side took 5hrs and I had to make some adapters because the rental tool from O'reilly's didn't fit and it was partially seized. Passenger side took 45mins. I hate ball joints.
HeartMyFairlady (12-22-2019)
08-06-2021 06:19 AM
350Z Project X
Suspension
10-10-2015 09:23 AM
