Removing bearing from hub...
The large bearing separator from HF should have enough purchase to get it off, always has for me.
http://www.harborfreight.com/automot...ator-3979.html
Install was even easier. Cleaned up the hub, spread anti-seize where needed, stuck in the freezer. Put the bearing on concrete floor, put a heat gun on it. Browsed YouTube for 5 minutes. Took the hub out of the freezer, set on a 36mm socket. Put the bearing on top and pushed down (it slipped on about 1/4"). Used a soft mallet to beat the bearing all the way on. Toward the end (1/8" away from flush) it was tight. I put the salvaged race against the inner race of the new bearing and applied a moderate amount of BFH. Perfect
That was last resort. Luckily, didn't have to.
EnjukuRacing
Suspension
10-12-2015 12:12 PM
EnjukuRacing
Drivetrain
10-08-2015 07:54 AM
