Abs Issue That Needs Attention
on
Hey guys I've searched this forum for any solutions numerous times and I can't find an answer as to what's causing this problem (that I haven't fixed already). So ever since I got my Z, 3 years ago I've had a problem with the abs system. A few months after I got the car I had the abs pump fail on me which caused it to stay on and drain my battery giving me the abs and brake light to be on, no biggie so I replaced the abs pump. Since it was so long ago I don't remember if the abs and brake light ever went away. So last year the lights on the dash and abs pump buzzing for 2 seconds when the wheels first rotate got really annoying and I replaced the rear abs sensors, light still doesn't turn off. I even changed the differential (reasons other than trying to fix this issue) I didn't expect it to fix it, and I was right because it didn't. Now that rain season is going to start I daily drive my car so I want to try and find the issue that's causing this for safety concerns. I have full aftermarket suspension, but even when I got the car it was 100% stock so I know it's not my suspension causing it. My z doesn't come equipped with tpms if that matters. Does anyone else have any suggestions on what I should be looking at ?
I've replaced
Abs pump
Rear abs sensors
Differential
Both rear wheel bearings
Symptoms
Once the wheels rotate about 2 times the abs/brake light come on and the abs pump buzzes for 2-3 seconds and stops buzzing after those seconds have passed. The light stays on and I don't think they have ever turned off since I've had the car
I've checked around the brakes etc numerous times and never saw anything out of the ordinary or damaged. I've scanned the car with my scanner and it's not throwing any codes.
Any help would be appreciated, thanks!
I've replaced
Abs pump
Rear abs sensors
Differential
Symptoms
General & DIY Moderator
Does your home scanning unit have the ability to check both BCM and ABS features? If there's CEL, there's a code in there showing. If not, I agree with trav, take it to a Nissan dealership and get a tech with a CONSULT III unit to diagnose what's going on.
350Z/370Z Tech Moderator
OK, all you anti-dealership people, here goes again.... This is definitely something for a Nissan tech to diagnose (and maybe fix, if it's a simple one).
Sidenote, saw the title of this thread and thought it was a Lounge fitness topic. My answer was: "Crunches and other core strengthening workouts."
Think.
on
Lol I see what you mean with the lounge fitness topic LOL sorry about that
I would take it to the dealer but I feel they're gonna say it's a result of my suspension etc which I know it's not because even when it was stock it occurred (they probably won't believe that) so I wanted to diagnose every possible option before taking it to the dealership
Lil Mierz
Interior
12-04-2015 10:12 AM
DarkCreep
11-28-2015 10:22 PM
savedbygrace
11-24-2015 06:26 AM
ukraini9mofo
11-05-2015 06:28 AM
