What did I break and how do I fix it?
Old 11-20-2015, 12:48 PM
SoCali-Z
SoCali-Z's Avatar
Default What did I break and how do I fix it?
Obvoiusly my Z isnt happy im selling her so she decided to do this the day the deal was supposed to happen... Today. Go figure.
The part that broke is anodized red and adjustable? It was dragging on the floor once it snapped. Camber arm? Control arm? tie rod?
Old 11-20-2015, 12:52 PM
iideadeyeii
iideadeyeii's Avatar
Old 11-20-2015, 12:53 PM
SoCali-Z
SoCali-Z's Avatar
Old 11-20-2015, 12:58 PM
SoCali-Z
SoCali-Z's Avatar
Originally Posted by iideadeyeii
Thanks bud. Sorry to need to be spoon fed but the part is the front lower link, correct?
Old 11-20-2015, 01:03 PM
iideadeyeii
I have no idea. Just match it up
Old 11-20-2015, 01:37 PM
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,292 Likes on 896 Posts
Looking at the photo, it's part #23: the forward radius rod. Jack up the Z, support it on jack stands and pull the RR wheel to confirm. Might want to check some of the other suspension components, as this radius rod does NOT break unless its been badly abused.
Old 11-20-2015, 02:27 PM
SoCali-Z
SoCali-Z's Avatar
Everything else looks ok... The strut looks stock...
Old 11-20-2015, 02:28 PM
blufc3s
blufc3s's Avatar
Originally Posted by SoCali-Z
Looks like it's an aftermarket replacement for part 23 as its adjustable?
Might explain why it broke.
Old 11-20-2015, 03:04 PM
SoCali-Z
SoCali-Z's Avatar
is this what i need
http://www.ebay.com/itm/Godspeed-Toe...mtr&rmvSB=true
Old 11-20-2015, 03:28 PM
venture210
venture210's Avatar
Pull your wheel off and take a picture of the component that busted. It's likely item 22 or 23 from the diagram
Old 11-20-2015, 04:08 PM
SoCali-Z
SoCali-Z's Avatar
Old 11-20-2015, 04:24 PM
icer5160
icer5160's Avatar
Based on the picture you took, it's item #22-Front Lower Link. Not very skookum welds there!
Old 11-20-2015, 05:16 PM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
Guess thats the problem with buying a car with aftermarket parts you didnt put on... When they break you cant put the stock non adjustable equivalent back on...
Its hard to tell if its 22 or 23.. Might want to go to the good side and identify what each part is from that side and you will be able to figure out what was changed to aftermarket.
If your going to sell the car just get a stock piece from a junk yard. I would rather eat tires then have crappie ebay suspension parts holding the car together.
Old 11-20-2015, 11:14 PM
terrasmak's Avatar
Received 2,284 Likes on 1,646 Posts
It's a Godspeed camber arm, buy a new pair of SPC arms.
Old 11-21-2015, 09:43 AM
tukeeg35
tukeeg35's Avatar
Looks like an adjustable rear camber arm. And stay away from godspeed parts in the future.
Old 11-21-2015, 10:29 AM
SoCali-Z
SoCali-Z's Avatar
I'm not I'm trying to figure out the part....
Heres the other side
Old 11-21-2015, 10:31 AM
dkmura
dkmura's Avatar
I think the OP was looking for a DIY on how to fix his Z and there isn't one. He's trying to sell his car and probably wants to do it the cheapest way possible. If that's the case, he can slap on a cheapo part and try to hoist it off. But if he wants to do it the RIGHT way, he should use a quality part and then have the Z realigned by a shop with an good laser alignment machine.
Let's hope we don't see another thread from a new Z owner who has handling problems with his "new" Z, that looks suspiciously like the one here.
Old 11-21-2015, 10:33 AM
SoCali-Z
SoCali-Z's Avatar
Its the camber arm... Shouldve just looked at the other side yesterday Lol
feelin dumb right now haha
My neighbor runs a tire shop. It will be aligned correctly. Im not trying to cheap out. Never have never will. I didnt put these parts on...
My local dealer has megan racing and ichiba
Anybody ever hear of ichiba? I think Ill just go with the megans for 150
Old 11-21-2015, 10:51 AM
dkmura
dkmura's Avatar
Glad to hear it, but you might want to stop and consider what you really need. If your Z is lowered considerably (and it's hard to tell from the photos you posted), an adjustable radius (or camber) arm might be necessary to bring the rear into factory specs.
But you might also consider OEM radius arms as well. They have no adjustment and are built from stamped and welded steel. They tend to BEND rather than break and I always keep a spare in my race trailer in case that happens at an event. Much cheaper if you can get a pair used and they are durable for normal road usage.
Old 11-21-2015, 10:52 AM
NoQuestionZ
NoQuestionZ's Avatar
Ichiba Is garbage. There's many threads covering this. Idk that megan is much better. I've had Kinetix on my Z for at least 3 years. Cheap enough and sturdy for a daily.
Quick Reply: What did I break and how do I fix it?
