KW V3 coilover question
I have been looking at a set of the KW V3 coilovers. Just wondering what else is out there in your opinions at around the $2500 price point.
I have also been looking at the Bilstien B16 PSS10 but not found much info about it.
Thanks in advance for any help
The OGs seem to love Springs and struts over coils
350Z/370Z Tech Moderator
The ability to set ride height that's dependent upon the ability to get it on the lift to adjust the ride height.
Which came first, the spring perch or the.....? Heh heh.... sorry.
But ya, if you're looking into the KWV3s, there aren't that many units that are going to do what you want.... independent jounce and rebound calibration. The Bilstein PSS-10 do (I believe) as do the BCR ERs but sorry, can't speak to them with any hands on. I'm one of them OG-types that HR ref'd in his post above. Laff....
Only coilovers I've had any experience with were on my fenderless car.
Stance Pro Comp 2 is another in your price range.
So lowering springs are to low for your need or not low enough
And therein lay the conundrum of the day:
I am reading some google VS articles and most seem to think the bilsteins are easier to adjust on the car. Making trying diff settings at the track alittle easier?
Sleeps in 350Z
I was close to ordering these recently, but found some useful info here on the forum from a couple of suspension gurus. Basically the Bilstein PSS10 is great for the street, but not a good track option. That's just what I read in a couple of threads today. It was enough to steer me clear and I'll probably go with the Ohlins Road and Track coilovers. Hopefully you have good luck with your PSS10s.
Club Moderator
the Hot Spot
the Hot Spot
I have the pss10's and they're great so far. I also considered the kw3's while shopping but unlike you i wanted a low drop with a reputable brand that offer lifetime warranty and have plenty of r&d etc. My car won't make it up on the lift unless it's an inground lift. During my research i found that the kw's trump bilstein... this is coming from BMW owners btw.
Anyhow, i love my coils.... i chose bilstein is bc (mentioned above) they're more of a street coil and kw's are track dedicated. Plus they lower the car a little more than the kw's at 1.7 all around instead of 1.5 inches.
Sleeps in 350Z
I read the KW's are more track focus but I also read tons of failures, broken this, noisy that. I couldn't find any bad reviews on the PSS10's. I'm sure they will be good enough for a newbie track guy (me) In the future I can try something different if the Bilsteins become a limiting factor.
I've had to rebuild my V3 twice already and gave up on the rebuild frequency, so I went to Ohlin DFV.
the independent rebound / compression adjustment is nice (but after a month, the adjustment gets old) Height is adjusted through preload on KWv3 while Ohlin is through the shock body.
DFV are 2.7k through Ohlin direct sales (paypal)
