Knocking sound when hitting bumps
Old 04-06-2016, 05:36 AM
jason08z33
jason08z33's Avatar
Default Knocking sound when hitting bumps
I have a 2008 base 6mt with 106,000 miles and for some Reason I hear a knocking sound when I go over bumps. It's only on the drivers side that I can tell. I'm wondering if it's a bushing or something that needs to be replaced but I'm still not sure. I know there was a thread in this already but no solutions were posted and it hasn't been a live thread since like 2012
Old 04-06-2016, 05:45 AM
Looch
Looch's Avatar
Could be any number of things. Bad strut, torn bushing, ball joint. Tough to explain suspension knocks online.
Old 04-06-2016, 06:04 AM
travlee
Master
travlee's Avatar
Received 9,047 Likes on 6,513 Posts
end link is another possibility, get under there and look... if you dont see anything, take it to a shop
Old 04-06-2016, 02:21 PM
Spike100
Spike100's Avatar
I agree with Looch and travlee. You need to get the car up on a lift and inspect the suspension components.
Old 04-06-2016, 02:29 PM
KJFire4Life
KJFire4Life's Avatar
Same as the other 3, inspect it, look underneath. Common fail points are sway bar end links, lower control arm inner bushings, lower control arm shock mount bushings. Take a look at ball joints, see if they are torn or have a lot of play with the wheels off the ground, There are a lot of different components, each one must be looked at and carefully tested for failure or problems. It won't take you long to find the problem, just go slow and one piece by one piece or take it to a shop and let them find it
Old 04-08-2016, 03:34 PM
NoQuestionZ
NoQuestionZ's Avatar
Check the wheel bearing too. I recently ran into a knock which turned out to be a loose axel nut. If you need a wheel bearing I have a Timken one BNIB.
Good luck!
Old 04-08-2016, 07:10 PM
Z1NONLY
Z1NONLY's Avatar
In addition to the suspects listed above, check your lug-nuts on the wheel(s) where the sound is coming from. Make sure they are torqued and not just "snug".
Old 04-12-2016, 06:04 PM
tyau
tyau's Avatar
Two weeks ago, I adjusted my front Cusco sway bar. In the past few days, I been hearing clunking from the front end, gradually getting worse. Turns out that my endlink nut was loose. Maybe you can start with that? If not, then it could be a wide variety of things.
MyZ32TT
NISMO 350Z
26
08-21-2016 06:58 AM
cincysilvias14
04-07-2016 07:13 AM
SilverGLE
04-02-2016 09:27 PM
EnjukuRacing
Suspension
03-30-2016 01:16 PM
Quick Reply: Knocking sound when hitting bumps
