370z Springs on 03 350z.? Good idea ?
Old 05-03-2016, 05:34 AM
ssmokeyy
ssmokeyy's Avatar
Default 370z Springs on 03 350z.? Good idea ?
I have a 03 350z and want to drop my car no more than .5 of an inch and want to make them little stiffer like around the nismo range. My idea is to use factory 370z ones but not finding much info on if this can be done or even tried. If that's a no go I have looked in to both tein models and not sure I'm really sold on them. I wish h&r sold there oe sport model for are cars.
Old 05-03-2016, 06:48 AM
turboed350z
turboed350z's Avatar
Check the spring loading.
You can easily lower the car with eibach pro kit.
Old 05-03-2016, 07:07 AM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,255 Likes on 2,316 Posts
^^ +1
Old 05-03-2016, 07:10 AM
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,292 Likes on 896 Posts
The Z34 has a shorter wheelbase than the Z33 and different spring rates for optimum ride and handling. As for lowering your '03 Z by 0.5", using Z34 springs will not help. You're better off looking at a coilover setup, than a Eibach prokit. Although it's less extreme than other Eibachs, it still drops the car by more than an inch.
Old 05-03-2016, 07:57 AM
turboed350z
Did not read the part where he only want .5 drop. My bad.
Anyrate, a good set of springs and shocks will be better than cheap coils. Pretty sure there are springs that only drops .5. Cant think of any off the top of my head, but theyre out there
Old 05-03-2016, 10:06 AM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
Half an inch... I got ya bro
Old 05-03-2016, 10:09 AM
dboyzalter
dboyzalter's Avatar
https://www.z1motorsports.com/suspen...0z-p-2103.html
Old 05-03-2016, 11:01 AM
travlee
Master
travlee's Avatar
Received 9,047 Likes on 6,513 Posts
i would do the s-tech over the h-tech
Old 05-03-2016, 11:05 AM
jhc
General & Tech Moderator
jhc's Avatar
Received 2,225 Likes on 1,594 Posts
I did Eibach Pros last month. More coils, more planted over rough terrain. It's roughly 1", my favorite $250 mod so far.
Old 05-03-2016, 11:23 AM
travlee
Master
travlee's Avatar
i had and loved the pro-kits, swapped to them from the s-tech
the s-tech is a good riding spring but not best for spririted driving
Old 05-03-2016, 11:28 AM
dboyzalter
dboyzalter's Avatar
How did you get the front struts out? Did you disconnect the sway bar? Mine was a real pita and I just got out the grinder and made them play my game.
My Massachusetts nuts are a bit crustyer than your Georgia nuts, I dont remove them if I can help it.
Old 05-03-2016, 12:41 PM
ssmokeyy
ssmokeyy's Avatar
Thank u guys for all the reply's.. I will put more info in to this. I have a custom body kit on this car that has no seams and I can't drop it more than .5 max but I want a stiffer than factory spring. It's a late 03 model so I here those are the worst for every thing. I'm going to go with bilstiens struts and shocks. Koni asks to much for them. Really I drive her hard but not on the track that much.
Old 05-03-2016, 12:51 PM
iideadeyeii
iideadeyeii's Avatar
Pics of molded body kit
travlee (05-03-2016)
Old 05-03-2016, 01:41 PM
92K1500
92K1500's Avatar
The Hotchkis springs should be perfect for what you want.
Old 05-03-2016, 02:03 PM
ssmokeyy
ssmokeyy's Avatar
U can look at pictures of this car and other I have at velocity automotive on facebook. Building a new business website once I get that up I will be shutting down the facebook one.
Old 05-03-2016, 03:50 PM
terrasmak's Avatar
Received 2,284 Likes on 1,646 Posts
Different front motion ratio, won't work well. Struts are also different
Old 05-03-2016, 09:01 PM
ssmokeyy
ssmokeyy's Avatar
So witch one would be better bilstein shocks or tokico blue shocks with tein s Springs?
Are the tein so Springs stiffer than stock?
Old 05-04-2016, 05:23 AM
iideadeyeii
What awful pictures on that group for advertising
Also when you say molded I assume the front/rear bumpers were molded
Old 05-04-2016, 06:25 AM
turboed350z
So you just want a stiffee ride? A drop doesnt gurantee stiff ride. Its all about the rating.
Old 05-04-2016, 06:51 AM
jhc
jhc's Avatar
Yes, d/c sway with torque wrench. The A arm bolts were more of a PITA bc I couldn't get my socket in there, so box wrench forever. ..
Sorry to hear about your nuts, mb if they got worked more often it wouldn't be a problem
I keed.
Quick Reply: 370z Springs on 03 350z.? Good idea ?
