Toe issues
Old 06-12-2016, 09:11 PM
emooheo
emooheo's Avatar
Default Toe issues
My 350 is lowered on coilovers with camber kits on front / back. I installed the rear toe bolts as well when doing this. I recently took my car for an alignment and the tech said that the toe was maxed out as was unable to get my camber any better because of this. What is most likely to be the issue with this? Is it possible that I did not install the toe bolts correctly / grind it out enough?
Old 06-13-2016, 03:12 AM
travlee
Master
travlee's Avatar
Received 9,047 Likes on 6,513 Posts
did you use the template when you did the grinding?
Old 06-13-2016, 09:27 AM
emooheo
emooheo's Avatar
I did, but I guess it could have still messed up.. maybe undershot the cut a bit
Old 06-13-2016, 09:35 AM
travlee
Master
travlee's Avatar
here is a good read, pay particular attention to page 9
http://www.batit.com/forumpics/spctoeboltinstall.pdf
Old 06-13-2016, 07:55 PM
rustyschopshop
rustyschopshop's Avatar
If travlee's post doesn't help... you may be sitting too low to adjust out, you may need to add camber to get the tow inline. I noticed you are running coilovers. Are they true or Oem style? If they are true style you can get toe arms to give more adjustment.
cbb7855
04-26-2016 08:40 AM
jmg35coupe
04-06-2016 09:33 PM
Siqcology
03-31-2016 04:32 PM
Quick Reply: Toe issues
