Front End Clunk
Front End Clunk
2003
130k miles
In the past 2 weeks this clunk has been getting worst. Getting it while tapping on the brakes coming to a stop. Clunk comes on at low speeds on bumps/dips in a straight line and while cornering left and right. Clunk is from driver side front wheel area.
I got alignment today to see if it could fix the issue but still loud and clear. I've looked under the car for bushing failure but none.
I have (all under 1 year, however noise has been progressing in the past month with the past week being the worst):
Hotchkis sways
whiteline end links
whiteline shock bushing
whiteline LCA bushing
Whiteline Compression rod bushings
New ball joints from concept Z
However i'm thinking the issue is from my compression rod bushing (replaced with whiteline a few months ago)
I've attached this picture for you guys, is it normal for the bushing to ride up like this at one end? This is taken from wheel well driver side front wheel. looking in at the compression rod bushing
130k miles
Hotchkis sways
whiteline end links
on
I too am having the same issue. We just replaced full lower suspension and wheel hubs upfront. It never made that noise before we did the work. Now that you pointed that out, I'll have to take a look at mine. If mines the same, I'd have to guess that that is the issue until somebody with no noise also shows they have the issue.
It's normal to ride that that, poly in this location is a bad idea. If it's touching it could cause a clunk.
How low is your car sitting ?
on
Mine is completely stock. It wasnt doing it before we changed the wheel hub ball joint, and lCA's, so I'm guessing it's what everyone else said it was. I'll also check the sways when I swap the engine next week. Car can't start, so I can't bring it around back to jack it up.
I get a bunch of front end noise ever since my Z1 "race" arms. And the sway bars and adjustable end links
kazx9r
09-27-2016 11:39 AM
Spears Is Faded
09-22-2016 07:11 AM
