rear camber kit and upper control arms
Old 10-24-2016, 06:06 PM
Tomek350Z
Tomek350Z's Avatar
Can someone explain the so called spacers at the bottom left and right?
Old 10-24-2016, 08:18 PM
terrasmak's Avatar
Received 2,284 Likes on 1,646 Posts
Those are a pain to work with, the new d ensign not shown is much better
Old 10-25-2016, 01:15 PM
deeliciousqueen
deeliciousqueen's Avatar
Just sharing my experience with Kinetix FUCA. Been to two reputable shops and they both dislike it. It is a blind adjustment basically you guess where the ball joints adjust and then if you don't get the specs you want you'll have to remove the wheel again adjust the ball joint and do the same thing over and over until you reach your desired spec.
I have nothing against Kinetix FUCA but just sharing my 0.2
Old 10-25-2016, 01:45 PM
Tomek350Z
Tomek350Z's Avatar
I figure, but I cant even imagine what they are for, the camber is obviously adjusted with the large nut/balljoint moving fore and aft. But what is the purpose behind these so called spacers? Caster?
thanks for the input, I have heard this from others as well
Old 10-25-2016, 01:57 PM
Tomek350Z
Tomek350Z's Avatar
https://www.z1motorsports.com/suspen...35-p-9583.html
looks like its for more camber adjustability
YardieXplorer
Mid-Atlantic
10-13-2013 07:19 PM
zred
05-16-2009 11:57 AM
gsazabi
08-17-2006 02:37 PM
SJTrackZ
04-27-2005 11:53 AM
Quick Reply: rear camber kit and upper control arms
