Z1 FUCAs
Probably China
Here are some representative specs I found based on the serial on the main heim joint - LDK JMX12T (on the particular UCAs I received):
http://www.ldk-bearings.com/en/pr04.asp?id=106
Similar avail on summit:
https://www.summitracing.com/parts/fkb-jmx12t
From another supplier:
http://www.wychbearings.co.uk/jmx12t...d_bearing.html
I was inspecting the suspension after my last track day and noticed slight play in the wheel and a clunking noise which ended up being the joint on the arm, which had some play because the nut had loosened slightly....since I didnt use locktite after my last camber adjustment.
If you break the nut make sure to use locktite when re-tightening, or check it frequently if you are tracking etc.
That's a well known problem with these arms,
