Stock track model
on
Stock track model
I have a 2006 track & want to know if the factory struts/shocks are mono-tube, or twin tube ? I'll be replacing all 4 soon. Also, what is the suspension difference between, say a base or touring model vs. the track model ? Thicker sway bars, lowered springs, stiffer struts ? All of the above ?
350Z/370Z Tech Moderator
There is NO difference between the Track suspension and any other trim level.
Track trim gets you aerodynamics (front, rear spoiler), Brembo brakes (big diff) as the main differences. And at least they're functional upgrades.
I just went through every listing I could find with model/version breakdown and that's not noted anywhere. Oh, and I'm NOT doubting you, PDX, just find that very interesting. Would love to get ahold of one of those and throw it on for kicks along with a stock all-model front to swap and compare. Except I threw my stock bars out a long while ago.
Just wonder if your '05 bar might be part of the 2004.5 suspension re-do.... Hmmmm.
Wow...... NEVER heard that one before.
The reason I found out was that I replaced the stock bar with a Hotchkis 34mm hollow front bar shortly after getting it home. The stock bushings matched the Hotchkis bar, and the Hotchkis bushings matched the stock front bar.
