Sway bar help. Will it fit?
Old 01-20-2017, 09:16 AM
NoGiFighter
NoGiFighter's Avatar
Default Sway bar help. Will it fit?
Hey guys so I bought an exhaust to replace my stock one that had completely rotted out. Found a stillen true dual for a reasonable price in my area. Problem was once I got it home and started installing it I found out that it is actually from a 350z not a 370. Now there are clearance issues once I get to the rear sway bar. The 370z exhaust is designed with a double hump to accommodate true duals while the 350z sway bar does not. My question is, is there an aftermarket sway bar for the 350z with the double hump or is it possible to fit a 370z sway bar on it.
This is where I run into problems
370 sway bar pic for comparison.
Old 01-20-2017, 09:28 AM
nizmo_0385
nizmo_0385's Avatar
What you meant to say is the exhaust is from a 370z not 350z. Simple solution. Run a 370z rear sway bar. Our cars come predrilled for the dual exhaust hanger. I also have an extra hanger and 370z rear sway bar. Pm me if you want them both. Yes it is plug and play. Ive done this on my 350z thats how i know.
Old 01-20-2017, 09:33 AM
NoGiFighter
My bad that's what I meant to say. I was on the treadmill wrapping up my workout not paying attention thanks for catching that.
Old 04-24-2017, 06:01 AM
bdoyle1
bdoyle1's Avatar
I'm running into the same problem Did you install the 370z rear sway bar on your 350 yet
