Z1 differential bushing kit question
Old 01-21-2017, 01:58 PM
coletrickle74
coletrickle74's Avatar
Default Z1 differential bushing kit question
Got everything installed and I'm putting the diff back up. I can't seem to figure out if you're supposed to re-use the upper tapered washer between the front diff ears and the subframe. I'm guessing you do. Or is the top rubber part of the bushing just supposed to sit directly against the subframe?
Old 04-01-2017, 07:47 AM
transamnut
transamnut's Avatar
I too could use an answer to this question................
Old 04-01-2017, 09:58 AM
coletrickle74
I couldn't get an answer from Z1, so I just reused the washers. I don't have any vibrations as of yet.
