350z not aligning
on
350z not aligning
So I got a Nissan 07 350z and I just got it repaired from a body shop after an accident problem is though front won't align. The guy at fire stone is telling me just my front left isn't aligning and it's either a knuckle or control arm. Is there any way I can know for sure. I have picture of the alignment paper.
350Z/370Z Tech Moderator
You point to camber being out of range. Camber is NOT adjustable on factory control arms. To properly align FRONT CAMBER on a Z, you need aftermarket FUCAs. These may also fix the toe as any adjustment to camber OR toe OR caster have a corresponding effect on all three aspects.
Example: https://conceptzperformance.com/spc-...33_p_18116.php
FWIW, a -1.8deg negative camber isn't that big of a deal (from tire wear perspective) BUT you will probably feel pulling one way or the other as uneven L-R camber leads to "off" caster and toe settings affecting straight line behavior.
I'd also have a look at the rear toe. That's also out of spec.
I had this problem too a while back - very similar to you I think:
But now on adjustable everything
