Brake rotors and pads
Old 03-28-2017, 10:27 PM
Tardo
Tardo's Avatar
Default Brake rotors and pads
Are 06/07 brake rotors and pads compatible with a 2003 model?
Tardo
Old 03-29-2017, 03:41 AM
travlee
Master
travlee's Avatar
Received 9,045 Likes on 6,511 Posts
no, front calipers are bigger on 06+
Tardo (03-29-2017)
Old 04-21-2017, 12:38 PM
OldSkool
OldSkool's Avatar
Planning to order Stoptech rotors and pads for my 2009 Roadster. Since I bought it used I'm not sure what I have now. I know for sure its not a BBK but I have rough-textured, silver aluminum calipers. Are these the performance brakes?
Thanks in advance for any replies.
Old 04-21-2017, 02:28 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,253 Likes on 2,314 Posts
Unless your brakes look like these...
...you have standard brakes.
To my knowledge, no ZRs came with Brembos (above) except maybe Grand Touring if that was even available on '09 ZR. But good to check as PO may have upgraded.
These are standard brakes:
Both images taken from my350z.com, if you own these and want them taken down, say so.
Old 04-21-2017, 06:40 PM
OldSkool
OldSkool's Avatar
Thanks for the info! I guess my confusion stems from the brake ordering process. After selecting "non Brembo" brakes, I then have to choose between "aluminum caliper performance" or "cast iron caliper
standard" brakes.
I will try to attach a couple quick pics. Sorry for the poor quality and dirty wheels.
Old 04-21-2017, 07:56 PM
MicVelo's Avatar
"Non-Brembo" will suffice for all models Z33 BUT 2009. Where the confusion PROBABLY lay is that in 2009, the cutover to the Z34 occurred and technically the 350z "no longer existed" but the ZR. However, the 370Z model had the Sport package (and Nismo) brake option (Akebono 4 piston F/2 piston rear)- which are/were aluminum. But when ordering for 350Z/Z33, "non-Brembo/cast iron" should work for you.
OldSkool (04-22-2017)
Old 04-28-2017, 01:39 PM
JMII
JMII's Avatar
FYI - those are Infiniti wheels with a slightly different offset then standard Z wheels.
Old 04-28-2017, 02:37 PM
travlee
Master
travlee's Avatar
wheel offsets were never mentioned until now
3vilbunny
12-08-2015 12:10 PM
mustardfj40
10-31-2012 08:21 PM
lgear080
South East Marketplace
03-16-2011 03:17 PM
kinethix
08-10-2009 10:09 AM
Quick Reply: Brake rotors and pads
