Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > Do It Yourself Guides > Brakes & Suspension (DIY)
Old 02-15-2007, 11:56 AM   #1
Mazinger Z's Avatar
DIY: Rear Adjustment for Tokico D-Spec Shocks
I've gotten some requests on how to do this simple mod. It eliminates the need to buy rear extentions if you have Tokico D-Specs.
First, take off both the plastic covers on the rear strut bar. Just pry them open, that's the only way. Becareful not to rip the plastic clips:
Next, use a flashlight to look inside to see where the top of the shock is. You want to drill a hole directly on top of that.
Note: Look at the position of the hole on the left. That's the new hole I drilled. It's not directly parallel to the OEM hole. After you've looked inside, use a sharpie to mark where you want the new hole. Start off by using the smallest drill bit. The metal is thick so keep at it. After you've made a nice little hole, change the drill bit to a bigger one and then a bigger one, until you have a hole similar to the OEM hole.
Then, take your adjustment tool that came with your Tokico's and find a hex wrench similar in size. I used one that's about 4 inches long but you may want to go to the hardware store to find a longer one - it'll be easier to adjust.
That's it - clockwise to stiffen and counter-clockwise to soften.
After this simple mod, you won't need to buy a rear extention or jack up your car to adjust the dampening. Good luck!
__________________
35th_SS 6MT
Volk - Borla - Nismo - Motordyne - Hotchkis - Tokico - Fiber Images - Evo R - Data Systems - Fast Intentions - Alpine - Kicker - Infinity
"Kids Shift Gentle"
Mazinger Z is offline   Reply With Quote
Old 05-10-2007, 11:49 AM   #2
sixsigmalarry's Avatar
Thumbs up Very nice!
Good to know! I'm buying a set late-May or early June.
__________________
1987 Audi 4000CS Quattro (The Dirt Devil), 1991 Toyota Corrolla (The Rustolla), 1991 300ZX TT, 5MT (V8 Eater!), 2003 350Z Touring, 6MT (no mods....just a JDM VTEC emblem...it's so sick! I got it at Pep Boys!)
sixsigmalarry is offline   Reply With Quote
Old 05-11-2007, 10:20 AM   #3
Clit Commander
bbs350z's Avatar
how do these work in conjunction w/ tein s- techs? does this lower it further (i dont want it lowered further)? i hear great things about these shocks.
__________________
boozt. eye haz it. yew need it
bbs350z is offline   Reply With Quote
Old 05-11-2007, 10:31 AM   #4
TECHNICIAN
THE TECH's Avatar
You can't change how low the car is with springs. They are a set rate and lowering height. Adjusting the shocks has nothing to do with ride height.
__________________
03 Z SOLD, 04 Z NOW
THE TECH is offline   Reply With Quote
Old 05-11-2007, 10:31 AM   #5
Mazinger Z's Avatar
Quote:
Haha...no one ever looks at this thread. To answer your question, no, shocks do not lower the car further. Ride height is only based on your springs (or coilover settings). They're good shocks
__________________
35th_SS 6MT
"Kids Shift Gentle"
Old 05-19-2007, 12:47 PM   #6
SlipZ's Avatar
i have a question:
i have this set up (D-specs) Springs and shocks. What is the best sway bar set that goes along with D-specs???
thanks for the info!
Cris
__________________
06 Silverstone
SlipZ is online now   Reply With Quote
Old 05-19-2007, 12:59 PM   #7
USN HM 350Z's Avatar
nice write up
__________________
-2008.5 Nissan Titan SE
*CST 4" spindle lift/Bilstein Shocks/JBA Exhaust/Volant Intake/HyperTech Beta Test Unit/N-Fab Steps/HID Lights Headlights & Driving lights/ BullBar with KC High Lights
-2006 Mazda Miata MX-5
*Bilstein shocks/ Eibach springs
-1975 S30 Right Hand Drive Fairlady Z(Project Car)
*SR20DETT swap coming soon
-2004 Nissan 350Z JWT TT (Gone, but not forgotten)
USN HM 350Z is offline   Reply With Quote
Old 07-16-2007, 01:56 PM   #8
Myfirst06350Z's Avatar
What do you mean by a rear extention? And possibly could I make the whole bigger? And really why didn't tokico think of this when making these for the 350z?? WTH
Myfirst06350Z is online now   Reply With Quote
Old 07-16-2007, 02:01 PM   #9
Quote:
Tokico makes a rear extension set that is flexible and able to go up and through the rear strut bar. Problem is they brake easily. This is a much better way to do it IMO.
There is no reason you cannot make the hole bigger if you want.
__________________
Old 07-16-2007, 02:08 PM   #10
Smile Here you go...
See this link to understand what a rear extension is...
http://www.g37forums.com/showthread.php?p=575
Why would you want to make the hole larger? As long as you can slide an Allen wrench in there, that's all that matters IMO. Also, I didn't drill through my plastic, I just snap it off when I want to make adjustments.
Lastly, judging from the extensions, I'd say that Tokico did think is this when they made struts for the 350Z. They just decided to make this an add-on part and charge us for it rather than include it. IMO, it makes sense. They'd probably raise prices including that part. That would scare away price sensitive buyers who could care less about adjusting their struts (crazy people!) and Tokico would lose business.
Cheers!
__________________
Old 07-16-2007, 02:09 PM   #11
Migliore Fine Wax
Chris @ Migliore's Avatar
qft! mine broke during the install. waste of 30 bucks! the vendor that sold them to me said he work something out but i never heard back from him.
just get a 5inch t-handle allen wrench , drill the tiny hole and be done with it.
__________________
Click below to access MiglioreWax.com
Chris @ Migliore is offline   Reply With Quote
Old 07-16-2007, 02:42 PM   #12
I guess drilling should be fine with a hole that size. Just my case is that I adjust my struts a lot and was hoping for something easier. What do you guys set yours to for autox and canyons? And are those settings bearable on streets? Even though I like my ride stiff.
Old 07-24-2007, 11:32 PM   #13
Questions. I got my rears in. When adjusting how do you guys know what setting you are in when using the allen wrench? And can you over due the rear adjustments when not using the key?
Old 07-25-2007, 06:38 AM   #14
mario23's Avatar
Turn it all the way clockwise to full stiff. Then from there, you turn it back a couple of times to your desired setting.
__________________
03 350Z Greddy TT HKS F-con iS - Built & Tuned at Japtrix
mario23 is offline   Reply With Quote
Old 07-25-2007, 02:36 PM   #15
yea I know that. When I turn it with the key it stops at a point and that is full stiff. But when you use an allen can you accidently go down even further? Thats what I am asking.
Old 07-25-2007, 02:39 PM   #16
mario23's Avatar
Its the same. I use an allen wrench for the rear shocks.
__________________
Old 07-25-2007, 02:41 PM   #17
So yours stop when you set it to full stiffness with the allen wrench?
Old 07-25-2007, 03:43 PM   #18
Mazinger Z's Avatar
Yea it should stop if you turn full stiff. Yours doesn't?
__________________
35th_SS 6MT
"Kids Shift Gentle"
Old 07-25-2007, 03:53 PM   #19
mario23's Avatar
Yes it stops clockwise. By all means turn it all the way clockwise first. I would even drive it like that to see how it feels then start backing it off.
__________________
Old 08-24-2007, 11:51 AM   #20
kamikaZ's Avatar
Should this be the same for any adjustable struts? I have the Koni Yellows but I havn't even taken them out the box yet and I'm not sure if system for making adjustments is the same.
kamikaZ is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
