New to the Z family
on
New to the Z family
I'm looking at buying this 2004 performance trim 350z but I need second opinions, and was wondering if you guys could help. Upon test driving it, I noticed the volt meter went from being between 14-16 dropping below 14. I could be wrong but that seems like it would be an alternator going bad. Also the transmission shifts smoothly except for 1st gear to 2nd. It feels like its grinding sometimes but most of the time it feels like you really have to force it. I looked it up and found that with most early model Z's the transmission wasn't the best but I'm not very knowledgeable so excuse me. It has only had one owner, all the maintenance has been documented, clean title and carfax. Anyway I would really appreciate your help and thanks in advance
Personally I wouldn't worry about the voltmeter
as long as the voltage is 13 and above you are fine....anything above 16 is bad too. 14 is ideal.
can't say much on the transmission.
350Z/370Z Tech Moderator
Early transmissions (not all but some...particularly '03 models) were known to have faulty 3rd gear synchros (ask me how I know about this....) but I've not heard anything about 1-2 gear change. There's a later model transmission that sort of cures the 3rd gear issue (known as a "CD009") but no guarantees because....
...your issue *might* be due to clutch slippage or not disengaging fully in that particular gear change.
A clutch job on a Z isn't cheap (unless you do all the work yourself) but it IS a normal wear item so be prepared.
Good luck and keep us posted.
on
Okay thank you guys for replying, I just got done with all the paperwork and all that the battery was going bad and they replaced it, gave me a warranty, and the final price wasn't to bad, coming out to be a little over 12k out the door. Today though starting the car and driving around I noticed that when i rev the motor theres a tiny rattle I don't know if that's normal or not, but it only happens occasionally and the first start of the day it makes a squealing noise for a moment and then stops. That's all I've noticed so far, although I feel like I still got a good deal, would you guys disagree?
$12k is about the going price (give/take dep. on condition, mileage).
Great on the battery.
Rattle... well, that could be ANYTHING.... exhaust clamp or something else under the car, belt tensioner, loose trim, etc. Isolate it to the area then do a Sherlock Holmes on it. Probably something simple.
Squeal on cold start. Belt is likely, particularly in the cooler weather. Not much to worry about but...
Good practice anyways on any "new-to-you" car is to look over service records to see what's been done and when; then go ahead and "stage 0" (baseline) the car by replacing any/all normal service items (belts, fluids, filters, etc) preemptively so YOU know where and what's been done then start your normal services from that mileage/time you replaced them.
But most of all, get out and enjoy your new toy!
Cheers,
Mic
Workshop12
03-23-2020 01:45 PM
Subarism
East Canada
09-23-2015 06:23 PM
