are these the correct steps
on
First I would say, do not compound your car without proper experience because a compound significantly reduces clearcoat and if not done correctly, one could burn through it and into the paint. Always start with the least abrasive product that will get the job done and go from there as needed.
You do not need to use spray detailer. I would suggest claying before polishing/compounding because if there is fallout on the paint and you do not remove it before polishing, the pad will pick up this debris and likely swirl/scratch your paint as you spin it across the surface at 1000+ rpms.
Just my suggestion
Just my suggestion
Old thread but here's my 2 cents worth:
1. wash & dry
2. clay bar (if needed...to test for contaminants, place your hand in a sandwich type plastic bag & rub acorss your paint surface, if it feels rough, you need to clay bar.)
3. polish if needed, like swirl & haze remover, Revive.
4. sealant
5. glaze
6. Excellent carauba paste wax
7. Use detail spray in between washings.
I usually use only steps 1. 5. 6. & 7.
1. wash & dry
4. sealant
5. glaze
08-06-2021 06:19 AM
