You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I have a problem that typical automotive wash formulas can't touch, even tried Dove dish washing degreasing soap, but I been washing my car last few days but repetitive process of soaping and sponging the crap out of it only to dry it and still see crap on the paint I can't really get out. The stuff stuck on the paint can be many things, road tar, sticky oil or tree sap, etc..... but I can basically sum all the crap up in one word.......... "goo"
I thought Mothers clay baring would help, but it made it worse.... so now I have another problem, I clay bared and washed the car after but I can still see a lot of the Showtime spray all over my hood and the rest of the car, couldnt wash it off, and elbow grease didn't work.
I'm using one of those fine tile/grout sponges you get at home depot which holds a lot of water, is there something else I should be using, is that why I'm unable to wash the residue of the car, not enough pressure ?
now I don't wanna use any sort of liquid abrasives/cleaners aka liquid sandpaper, my paint couldn't handle it...... but what I am looking for is a car wash soap that will actually clean the car and remove or degrease the crap that's stuck on the paint as opposed to just foaming it up and not making a difference like all the soaps I tried.
can anyone point me in the right direction please and thank you
__________________
(oO:::\___/:::Oo) (DPE-wheels) // Satin Cocaine White
If you have "GOO" try Goo-gone or another cleanser. In either event - when you're done - your car will need an entire POLISH and WAX because you've stripped it with the dish soap. If in doubt, take it to an automated car wash. They use HCl to strip debris (and clear coat). Again - you'll need to follow with polish and wax.
__________________
Quote:
Originally Posted by solidfish
Hey scott. Thanks for the ride by the way. Your car and driving is sick. Literally, I was sick. It was like riding a mad rollercoaster. The car turns like its on rails. And the braking was unreal. So many times I thought we were going to fly off the track. Absolutely nuts, but it was great fun.
wash w/dawn
clay bar car
wash again w/meg's gold car wash
polish
wax/seal
use a 2 buckets one for soapy water/ one for rinse, prefer grit gaurds in bottom a plus.
sponges suck, use a 100 cotton towel or mircofiber wash mit, which gives dirt more area to get trapped in.
I should have mentioned about my paint job.... it's a semi gloss type satin clear coat, so I can't do the typical stuff you guys are able to do with regular clear coats, I'm unable to wax the car, I'm not sure if I can even use polish. I'm pretty much locked down to your typical soap sponge and water routine for the lifetime of the paint or car.
That's why I'm looking for the best available degreasing/cleaning car wash soap I can get my hands on, and I'll take care of the rest with elbow grease.
here's the car so you can get an idea of what the paint is about
__________________
I'm a full time painter at a Dodge dealership body shop .. I've painted a few sets of wheels "satin" black for challengers
you need to find out if the clear was a "satin clear" or an additive was used to create the effect (might make a difference or might not, but ive used both)
something you could try is take some rubbing compound with a microfiber cloth to a corner somewhere and see if it changes the SATIN finish to a glossy finish
if it does .. you wont be able to buff the car or polish it
if it does not make the spot shiny and the area stays satin .. then you can run over the whole car with a buffer and some compound .. that has to take the goo or any contaminates off (thats how you clean a white car for paint since there cant be ANY dirt on a blend panel)
another thing you could try is how we prep cars for paint .. wash the car with a spray can of glass cleaner .. then follow up with some wax & grease remover (they have it at auto parts stores or auto paint stores)
IF nothing works .. take a microfiber with some lacquer thinner .. that has got to take whatever is "goo" off the car
dont worry .. it wont hurt the paint unless you bath the car in the stuff (but I would try the corner thing just in case since its a satin clear) .. just wipe a panel with a soaked rag / microfiber then follow up with a dry one .. should work
fck, I just went at it again 10 minutes ago testing on my hood.... I clay bared again, used degreasing dish soap once again and microfiber towel wiped it... and before my hood was flawless.... but now there's dried up water marks all over it thanks to the Mothers Showtime Clay Bar lubricating spray!!! so I got two problems now
basically the lubricating spray left residue all over that looks like water marks... like I sprayed it on and let it dry out in the sun and it's baked in or something, I cant elbow grease it off the hood....
I'm not quite there yet, but I'm close to hitting the panic button here... now all the road grime on my skirts and door is very secondary and my primary concern is getting this Showtime Lubricant off the car..
what you guys think would do the trick ?
__________________
Adrian, I tried Turtle Wax polishing compound on one area of my hood before to get off ink, and I would not want to use it again, as it left abrasive swirl marks that are minor, but still there.... I will give that a try tomorrow but using moderate pressure since I don't want any more swirl marks
this is the one right here
if that doesn't work, I will panic and give up on this satin ********, it's been a shltstorm trying to keep the car clean since the day it came out the body shop, Jay Z might have the right idea, go with a regular clear, lol
__________________
^ true... I never really got any feedback from my body shop guy on how to properly clean it and maintain it, he didnt know either, he paints drift cars and crashes them more often than he washes them I don't think he is too concerned about show car finish and maintenence....
I'm gonna stop by a detailing place tomorrow and have them take a look, I just tried glass cleaner it didn't work...
gonna try the Turtle Wax polishing compound tomorrow as well I think that might work, either way I'll be hitting up the detailer sometime tomorrow for sure
__________________
Don't try the turtle wax compound yet. I"m still trying to find out information about it. But I need to know more about the paint/what is on it/pictures as well.
I really did not know that satin/flat paint was ridiculously that high maintenance to take care of..
Response from someone off Autopia..
Depends what it is, if it is bonded contamination such as iron or something of that nature a decon kit could be used. If it is sap, tar and the sort then use the proper chems to treat it. But if you use an abrasive polish you will get rid of the "pits" that create the satin look by leveling the clear which will create a shiny spot and not keep that satin look. A polish that is a pure polish, non-abbrasive/chemical polish is what is needed.
Satin and flat paint is hard to keep up with as you cant correct and scratches in the paint and the pits can get "clogged" with wax and have a yellow tinge sometimes thus you want to make sure all old wax and sealants is removed and new layer is applied
You can go on autopia.org and go to the cananda section to find a local detailer in your area..great guys on there who knows what they are doing.
Just use a good soap and then "Menzerna" cutting polish, white pad and a porter cable polisher...here are my results... $30 a bottle but worth every penny..I tried everything autozone and advance had on their shelves to no avail..claybar wouldn't get it done....but this product is amazing! Chalk it up to having the RIGHT tool for the job... http://www.detailedimage.com/Menzern...-P72/32-oz-S1/
direct reflection in the paint..
same distance just turned camera 45 degreees to the right..
You need to re-wash the entire car after the clay bar & do it in the shade. You can read the how to's on: www.detailedimage.com
Good ruck
__________________ chewwwy momma, hot diggety & shazam, be manly & have a good day.
Did you guys not read why he cannot go with something abrasive such as menzerna? He can only use the pc to apply a paint cleaner or wax using something like menzerna would not work as it'll just make the satin/flat clear coat glossy again..
^ He is just asking about why the claybay left the car looking like crap. Gave very simple instructions. No mention of Menzerna. His paint for 1 thing is way to fresh to be needing such an aggressive process like this.
Good ruck
I always wash my car after sundown out of direct sunlight, so I wouldn't dare clay bar anytime before. When I clay bared it the first day, I soaped the whole car up and elbow greased like a madman with Dove degreasing soap since I know Clay Bar leaves residue...
I clay bared and washed last night at 11 pm in my garage so the work is being done right I know how to do it, it's just nothing has been effective so far the paint is difficult to work with.
Quaker I will print out that response from Autopia you posted for me and give it to the detailing shop I'm going to today, it's really helpful. I am going to try one last time dealing with it myself, will use a few different degreasers and bug/tar removers but will be trying it with a pressure washer as a last resort.
as for the greasy hazy water mark looking crap all over the car I realized that it's not just left over Showtime Lubricant spray, it's mostly goo left over from the actual Clay Bar.... which sucks
__________________
what I just realized was that I need a car wash I can pick up off the shelf that is harsh enough to strip wax.... the residue that the Clay Bar left on the car is actually really wax like, and I knew from the beginning I was never allowed to wax my car.... now I know why, I need a car wash formula that will strip wax off the paint, in all the ones I've seen under the description it always says it "Will not strip wax off the paint"
what do you suggest ?
__________________
