350Z Race car built to current Grand Am Koni Challenge GS specifications
For sale: Nissan 350Z built to current Grand Am Koni Challenge GS specifications
www.constantradiusracing.com/350side.JPG
www.constantradiusracing.com/cockpit1.jpg
www.constantradiusracing.com/cockpit3.jpg
All wiring diagrams included. All relays and fuses are labeled for clear understanding of function.
This car is track ready. Just a corner weight and ride height adjustment is all that’s needed.
Weighs 2900 lbs.
Never crashed. Never wrecked. Paint is in showroom condition. Spares available as well.
Serious inquires only. Please contact rich@nohotwireracing.com
- TIG welded full roll cage, stripped, seam welded and car prep done by Impact Engineering
- 3.5 liter V6 race motor, Tilton flywheel and clutch
- Custom long tube header, and titanium/stainless steel exhaust Coast Fabrication mufflers
- Bosch MS 4.3 ECU and Grand Am approved wiring harness
- Bosch C4 data acquisition
- Chassis harness has connectors for 3 way accelerometer, YAW sensor, shock potentiometers, steering angle
- Deutsch Autosport connectors throughout the vehicle
- AIM lap trigger
- Bosch DDU4 fully customizable display.
- Removable steering wheel has controls for 6 driver selectable pages, display brightness control, radio button, pit speed limiter and fuel reset.
- Carbon/Kevlar NISMO V3 body kit as approved by Grand Am
- Carbon fiber headlight replacements (headlights available for night races)
- Functioning wiper and highbeams
- Dual dry break fuel tank with rollover and discriminator valves
- Carbon driveshaft
- Primary and secondary fuel pumps, car can run down to ½ gallon before starvation
- StopTech front brake calipers and rotors. Brembo rear calipers.
- 3” brake ducts to front rotors
- Tevis stand alone ABS system, with brake bias bar
- 3” thick C&R large capacity radiator with built in engine oil heat exchanger
- Koni double adjustable shocks
- 350evo sway bars
- 350evo front upper A-Arms, camber adjustable
- Cobra seat and 6 point harnesses
- Custom ultra-low seat mount on slider for taller drivers
- Switches are all Otto aircraft switches, circuit breakers are Klixon
- Wired for Grand Am Delphi transponder
- Hard wired for Motorola Radio
- AMB transponder with driver ID, hardwired
- Accusump
- Electrical fire extinguisher
- Jongbloed wheels with Hoosier tires
- APR wheel studs
- Driver accessible electrical cut off
- Iso-Torque rear differential with cooling radiator and fan
- Gold heat shield in engine bay and transmission tunnel to reduce cabin temperature
- NISMO power steering cooler
Weighs 2900 lbs.
on
Oh NOOOOOOOOOOOO! You guys are my heros. You can't sell this car! You are Nissan racing in NA as far as I'm concerned.
Seriously- very sad to see this but GL with the sale! My condolances.
[/SIZE][/FONT][*]Koni double adjustable shocks
on
Can't believe this is not sold although I hate to see it. I am hoping if it takes too long, you guys will change your mind!
