Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > General > The Lounge (Off Topic) > Computer/Tech
Old 07-24-2008, 10:24 AM   #1
Custom Lights
TBDesigns@CiNcity's Avatar
Anyway to install windows XP over Windows XP?
OK I got a good XP now and not a bootleg one but my question is! Is there anyway to load XP over the old XP with the new serial number without formatting or losing all the info I have on the PC? My dad has over 300GB's of business stuff and I can't loose that ****.
__________________
TEAM DNF - Nade Whore || CiNcity Designs || CiNcitydesigns.com PayPal and Credit Cards accepted! Custom lights FTW! R8 Mod, LED, halo, color matched, retrofit, side markers, reverse, tails, etc... PM for prices! WTB your used and broken lights. ANY condition complete or not. || WE ARE LOOKING TO SPONSOR A FEW CARS Visit our forums if your interested http://www.cincitydesigns.com/phpBB3
TBDesigns@CiNcity is online now   Reply With Quote
Old 07-24-2008, 10:27 AM   #2
AKA Curbz
wasuber's Avatar
500 GB external HDD is your friend, back that ish up!! Then install fresh "legit" copy and you're good!
I don't think you can go from corp, I'm assuming here to vanilla XP... But I may be wrong.
__________________
"CURBZ" [03' -DB Touring 6-spd] : 98' A4 1.8T : 06' Titan LE: 07' Pathfinder
"You never go full retard" - Kirk Lazarus
wasuber is offline   Reply With Quote
Old 07-24-2008, 10:30 AM   #3
Custom Lights
That's the thing he has stuff like games (WOW) that can't be backed up that is the problem. I have a 1 TB external HD but can't backup the games.
__________________
Old 07-24-2008, 10:31 AM   #4
Z_rican's Avatar
yes you can, give me a sec and ill find out for you
Z_rican is offline   Reply With Quote
Old 07-24-2008, 10:32 AM   #5
Custom Lights
Quote:
Thanks
__________________
Old 07-24-2008, 10:32 AM   #6
Z_rican's Avatar
http://pcsupport.about.com/od/produc...hangexpkey.htm
In the text box in the Run window, type regedit and click OK. This will open the Registry Editor program.
Locate the HKEY_LOCAL_MACHINE folder under My Computer and click on the (+) sign next the folder name to expand the folder.
Continue to expand folders until you reach the HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\Current Version\WPAEvents registry key.
Click on the WPAEvents folder.
In the results that appear in the window on the right, locate OOBETimer.
Right-click on the OOBETimer entry and choose Modify from the resulting menu.
Change at least one digit in the Value data text box and click OK. This will deactivate Windows XP.
Click on Start and then Run.
In the text box in the Run window, type the following command and click OK.
%systemroot%\system32\oobe\msoobe.exe /a
When the Windows Product Activation window appears, choose Yes, I want to telephone a customer service representative to activate Windows and then click Next.
Click Change Product Key.
Type your new, valid Windows XP product key in the New key text boxes and then click Update.
If you're taken back to the previous screen and prompted, choose Remind me later.
Restart your PC.
Old 07-24-2008, 10:34 AM   #7
Z_rican's Avatar
just change the key and you should be str8!
Old 07-24-2008, 10:34 AM   #8
zstreet86's Avatar
i'm not sure if a repair will prompt you for ro the key again or not, if it was home you could "upgrade" to profesional without changing anything. if its pro to pro, you should be able to just enter a new serial key (google for steps if you dont know how).
i would recommend a fresh reformatted install with every operating system installation, you should back up your information anyway when you do that, so you might as well back it up and do it right...
zstreet86 is offline   Reply With Quote
Old 07-24-2008, 10:35 AM   #9
Custom Lights
Thanks I'm going to try that tonight. I hope nothing messes up!
__________________
Old 07-24-2008, 10:36 AM   #10
Z_rican's Avatar
Let me know if it works!
Old 07-24-2008, 10:38 AM   #11
Custom Lights
Hey also if it works I need to install SP1 it's not going to delete or mess anything up installing SP1 right?
__________________
Old 07-24-2008, 10:46 AM   #12
Z_rican's Avatar
Nope, it wont mess anything up!
Old 07-24-2008, 10:47 AM   #13
Z_rican's Avatar
WOW can be backed up. It does not need to be installed to work. It can run ffrom just having the folder.
Old 07-24-2008, 10:51 AM   #14
Lead farmer
Kirk Lazarus's Avatar
Try the registry edit like mentioned before.
If that doesn't work...
You can reinstall XP under a "repair" and it will prompt you for the serial number. This is where you can enter in the new serial number.
__________________
Ben
Quote:
Originally Posted by stud_daddy
Pretentious tough-guy avatar picture, owns a sports car, fantasies of people's moms ....... you do realize that you do fit the profile of a small-town, pint-sized male with an ungratifying small penis ...... and you know it don't you?
Kirk Lazarus is offline   Reply With Quote
Old 07-24-2008, 11:54 AM   #15
Custom Lights
Cool thanks guys I'll try this out tonight.
__________________
Old 07-24-2008, 12:28 PM   #16
MY350Z.COM Sponsor
dspiel's Avatar
it may not work just an fyi, it has to be the exact same version of XP.
For example if you have purchased a retail copy of windows xp and you try to change the key to a windows xp key that came with your dell it more than likely wont work.
__________________
M1 Autosport
M1 Autobody www.m1autobody.com
11668 Ramona Blvd. El Monte, CA 91732
dspiel is online now   Reply With Quote
Old 07-25-2008, 06:11 AM   #17
Z_rican's Avatar
So, did it work?
Old 07-25-2008, 08:33 AM   #18
Custom Lights
haven't tried it yet most likely tonight or tomorrow night I will do it.
__________________
Old 07-25-2008, 10:14 AM   #19
Lead farmer
It'll work if you repair reinstall xp.
__________________
Ben
Old 07-25-2008, 10:18 AM   #20
Custom Lights
I'm going to do the regedit that Zrican posted.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
