Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > General > The Lounge (Off Topic) > Computer/Tech
Old 07-24-2008, 05:34 PM   #1
MDeezy's Avatar
Remote Desktop
Trying to setup something between a few of my computers.
I have a desktop stationed at my Moms house (45min drive) and I have my laptop at my house. I would like to use remote desktop to connect to that computer and do anything that is needed on that computer.
How can I establish such a setup without needing someone at the other computer to accept the invitation and allow me to take control of the computer.
thanks
MDeezy is offline   Reply With Quote
Old 07-24-2008, 06:14 PM   #2
Do WHAAAAT!?
TreeFiddyZee's Avatar
You could put a VNC server on your mom's machine and a VNC client on yours.
A "for instance" is Vine server and you could use Chicken of the VNC for the client. Both are freebies.
__________________
Is math an sgàthan sùil caraide.
TreeFiddyZee is offline   Reply With Quote
Old 07-24-2008, 06:18 PM   #3
Way to complicated.
Just allow remote connection on the computer you are trying to connect to via:
right click my computer
properties
remote
check: Allow users to connect remotely to this computer
If they are behind a firewall (Linksys most common) then you will need to configure port forwarding on port 3389 from the router primary IP to the private IP of the computer your connecting to.
then just type mstsc in run and connect to the public IP followed by :3389 (RDP)
You will be prompted to login so ensure you the account you use is an administrative account.
ATX350 is offline   Reply With Quote
Old 07-24-2008, 06:22 PM   #4
Do WHAAAAT!?
I'd have to think that would open up a pretty massive hole into her computer. Oh yeah, I mean another hole, it's Windows after all.
__________________
Old 07-24-2008, 06:24 PM   #5
No, its not. All servers in a web hosting environment use these settings.
Old 07-24-2008, 06:28 PM   #6
Found an article for you:
http://www.microsoft.com/windowsXp/u...moteintro.mspx
Old 07-24-2008, 06:28 PM   #7
and how to configure port forwarding:
http://portforward.com/english/route...4G/default.htm
Old 07-24-2008, 06:45 PM   #8
MDeezy's Avatar
Quote:
Originally Posted by ATX350
Way to complicated.
properties
remote
Gotcha I'll give this a try.
I had VNC before and used it but hadn't set it up from different computers that aren't on the same network. Going to try setting up these setting and see if that works.
Old 07-25-2008, 05:10 AM   #9
krono's Avatar
Way to complicated.
properties
remote
glad someone knows what they are talking about.
krono is offline   Reply With Quote
Old 07-25-2008, 05:15 AM   #10
ZCCO Member
430ztt's Avatar
or next time you are at your mom's house, download LogMeIn free onto her computer. Then you can log into her pc from anywhere in the world. You would just go to LogMeIn.com and type in your username and password and can access any computer you have setup under your account.
I used this for tons of customer PCs when I had my own IT Consulting business...the free version works great.
__________________
_____430ZTT_____
ZCCO Member #58
430ztt is offline   Reply With Quote
Old 07-25-2008, 05:36 AM   #11
VP ZSPORT.ORG
SOLO-350Z's Avatar
Actually no they don't. It is highly recommended to change that port in the registry to something other than 3389. Which we have done on all our servers.
__________________
2007 NISMO 350Z #0044 Silver Alloy - K&N / DEI / Alpine / Valentine / Xpel / Llumar / StopTech / Motul / Ferodo / BFG KDW2 285x35x19, 255x40x18 / UPREV Ordered (December 6th-13th)
SOLO-350Z is offline   Reply With Quote
Old 07-25-2008, 07:51 AM   #12
Sleeps in 350Z
cheshirecat79's Avatar
Yes, please use logmein.com and make this easy on yourself.
cheshirecat79 is offline   Reply With Quote
Old 07-25-2008, 07:53 AM   #13
DO NOT OPEN UP YOUR FIREWALL for remote desktop thats dumb..
Better off getting http vnc software. like logmein
jebz240 is offline   Reply With Quote
Old 07-25-2008, 07:58 AM   #14
shift_mygtr
blasian's Avatar
Quote:
+1
3389 just gives away that you can RD into the machine. I changed mine on my desktop when I was using RD.
__________________
www.my350z.com/ - www.boostedimports.com - 2003 Daytona Blue Touring - Stock - Team DNF - Official grape drinker, mic dropper and informer that bird is the word
Quote:
Originally Posted by bboypuertoroc
where where you?
They stole my grape drank
blasian is offline   Reply With Quote
Old 07-25-2008, 11:12 AM   #15
SuperMod j/k :)
Wired 24/7's Avatar
remote desktop will work fine (i've set this up on several computers), but you need something that will tunnel one internet connection into the other.
I recommend using a free program called Hamachi, it sets up a VPN (virtual private network) amongst any number of computers anywhere on the globe. It basically makes the computers as if they are networked behind the same router.
Once you setup Hamachi (which is basically config-free), then set the host computer to allow incoming remote desktop connections, this is in the "remote" tab under "System" in control panel.
Then make a note of the COMPUTER NAME on the network. you might want to set it to something easy to remember.
Then you need to make a PASSWORD for the account on the host computer otherwise remote desktop may not work.
Finally, log all the computers into the same VPN on Hamachi, and load up remote desktop, then when you connect, just type in the COMPUTER NAME into the remote desktop connection
I do this and it works alright, but if the internet connections are slow, then it will be painful to use.
__________________
05 SB Touring 6MT - Hotchkis - Volk SF Challenge - Stoptech Stage 2 - BFG Tires - Project Kics Neo-Chro Lugs
Motordyne MREV2 + 5/16" spacer - JWT Popcharger - Kinetix HFC - Greddy Emanage Ultimate - Cipher
New to my350z? Have a question? Please read this thread first: Top 100 Questions Thread (CLICK) (UPDATED 4/5/08!!)
SEARCH= SERIOUS BUSINESS: http://www.my350z.com/forum/search.php
Wired 24/7 is offline   Reply With Quote
Old 07-25-2008, 02:07 PM   #16
MDeezy's Avatar
good info Wired. I'll try that out and see. the connection at my Moms house is a little slow if my sister is on it (man she's a bandwith hog sometimes). but for the most part should would out pretty decent. I'll give it a try
Old 07-26-2008, 12:55 AM   #17
solidsnake's Avatar
I use VNC to connect to my work PC. Works great.
__________________
Team DNF !!!Goodbye Turbonetics!!! What will the future hold? NA powa for now... Nismo/Motordyne/Hotchkis/JWT/Berk/Enkei/Toyo... More to come soon...
Xbox live GT: turboz33
solidsnake is online now   Reply With Quote
Old 07-26-2008, 01:03 AM   #18
mrg1981's Avatar
I have used all of the recommended solutions in this thread. The easiest, trouble-free method is using logmein free. I have this on about 200 computers and it works great. Simple to use, logs all activity, she can disable it if she wants, nobody has to be at the computer when you log in, and very secure. The Hamachi is a VPN software and is really not for the RDC. You can use RDC without it, is what I mean. Hamachi is great. I have it between my office and my home and I no longer have to keep multiple copies of all work files and I don't have to keep track of updating every time we change something. For this application, however, logmein free is the best IMHO.
__________________
Greddy TT, Built Longblock, Built 5AT, Pro-EFI, Etc, Etc, Etc 525WHP @ 14 PSI, high boost tune coming soon.
mrg1981 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
