Thread Tools |
#1 |
Server Help
Hopefully the tech guys can give me some insight...
Basically i have 5 computers with an employee on each one. I want to be able to monitor the each computer from one single computer. See what website they are curently surfing, what emails they wrote, etc. On top of that i want to have one centralized location for all the applications and data. So the 5 desktop computers i currently have should have nothing on there. They should have to login to the server and from there run mozilla, openoffice, quickbooks, and a couple other files. Anyone want to give me some insight on what i would need, and so on? |
#2 |
ZCCO Member
Im not sure but you may be able to do it all with Virtualization. Just use the 5 desktops to "session" into the virtual server and you could have virtual desktops created. This would centralize all your files and programs to one server...
Now I am new to virtualization and have minimal experience with it so far but I think it can work for you. Would also cut down on having to upgrade each desktop in the future, you would only have to upgrade the server since everything is in a virtual environment.
__________________
_____430ZTT_____ ZCCO Member #58 |
#3 | ||
Quote:
as far as what you need, you just need a basic server. i actually work at dell so if you need something i can set you up with a server specialist if you want some quotes or something. and this is not me trying to sell...im trying to help lol.. edit - virtualization is also very expensive due to the software and upgrades you would have to do to compensate
__________________
Quote:
#4 |
It really is simple what you want but like craka350z said, you will need a server. After that it's a little setup here and there and a couple programs and you'd be in business. You can order a starter server from Dell with Small Business Server 2003 and you'd have most of the stuff that you would need.
#5 | ||
Quote:
__________________
Quote:
#6 |
Google for employee monitoring software...lotta stuff out there. Save your money, no server needed.
#7 |
Depends on how complex you want to get, but a server and SBS 2003 is probably your best bet. After that, set yourself up as an admin and you are all set.
#8 |
tkman35 -> omq
Terminal Services for Microsoft or Citrix for the applications. you won't be able to block internet access unless you enable access lists on your firewall/router, that or use a proxy server. do you really need to go this route? i'd imagine at the end of it all you're going to have some pretty pissed off employees.
__________________
Team DNF | Putting the "I" back in "TEAM" xbl/old master q - psn/oldmastahq |
#9 |
Well you can block/monitor Internet access if you install a software that is for that like websense or something. Websense is a little expensive but they did just buy Surf Control, which was a great program that was easy to use. I think that Websense has an "express" version but I haven't used it yet to say whether it's any good or not. Most of them require running Active Directory to be able to view/control from a central location.
#10 |
You're planning on monitoring their emails and web surfing? You'd better have a serious banner warning when they log on explaining the fact that you're monitoring their every move. I think a better idea is to have a detailed acceptable use policy that they have to sign. If you have to micromanage your employee's actions on the internet, perhaps it's time to get new employees or new management.
__________________
History is not going to be kind to liberals. With their mindless programs, they've managed to do to Black Americans what slavery, Reconstruction, and rank racism found impossible: destroy their family and work ethic. - Walter Williams |
#11 | |
Quote:
__________________
I got a chevy with a mopar cam, I'll be your jonny on the spot! |
#12 | |
Quote:
I can't imagine any time where I'd need a server so I could read employee's email. Acceptable use policies and training should be more than enough deterrent for improper computer usage. If it isn't, the employees shouldn't be working there anyways. It seems like a major waste of resources. To answer the OPs question, it sounds like he's looking for a terminal server/thin client solution.
__________________
History is not going to be kind to liberals. With their mindless programs, they've managed to do to Black Americans what slavery, Reconstruction, and rank racism found impossible: destroy their family and work ethic. - Walter Williams Last edited by jesseenglish; 07-28-2008 at 07:43 PM. |
| Thread Tools | |
